Thread: would my car benefit from
    Regular Member bunsen1's Avatar
    suffolk
    Default would my car benefit from
    i have a 54 reg 150 cdti sri ,standard, done the air box mod but would any additional cold feed benefit it? extra holes or something, and how and where to put them if yes? cheers
    Full Member lizard's Avatar
    Oct 2006
    southampton
    15 Post(s)
    I'd be interesting this one too if anyone can help, seen the VXR done but no other models.....
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    not to sure, but an aftermarket airbox filter may alow more are to pass through freely, as for sticking a k&n cone filter beside the engine were all the hot air is is a waste of time, as petrol cars thrive on colder air for better combustion, aslong as your getting a steady flow of cold air then thats plenty. putting extar holes in the air box wouldnt help either as there will be a steady flow of air already in the air box, and the car will only allow as much air as the filter is letting through. hard to explain lol
    suffolk
    wasnt sure if it would be beneficial or not for a diesel
    suffolk
    thanks though
    Mar 2011
    Donegal
    Quote Originally Posted by bunsen1 View Post
    thanks though
    no probs, someone else might have a different experience though.
    Feb 2007
    North west
    cold air helps diesel just as much as petrol, cold air is more dense and therefore more oxygen rich. Have a look at the front grill where your airbox cold air feeds comes out. On some models the grill is blocked off in front of the cold air feed - you can open this out to improve the flow but you wont notice any difference.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by rob 2.2dti View Post
    Is that because the feed comes from lower down? Someone on here (Big Sig?) recently posted that there was a valid technical reason for blocking off the upper grill on the 1.9 CDTI's. Also I read somewhere that it improves aerodynamics (and lowers emissions?).
  1. £2k a week benefit.
    By Hideous in forum The 'Off Topic' room
    Last Post: 16th July 2010, 11:47
  2. Benefit cheat ???
    By Gr4eme in forum The 'Off Topic' room
    Last Post: 13th February 2008, 12:30
