Thread: vectra 2.0 dti
    Jan 2010
    norfolk
    Default vectra 2.0 dti
    hi again im thinking of servicing my vectra and going to change fuel filter but in manual it says it needs to have pump connected to fuel lines before starting the car , can you buy the pump vauxhall use to do this thanks
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    just buy a hand priming pump mate thats what i did with my old dti and filll the filter housein up with diesel to
    I just seviced a 2.0 dti at the weekend and it started straight away after the work was carried out. Just make sure you fill the filter housing with clean fuel after the new filter element is in place, refit the housing lid and start the engine. It worked for me anyway.
    PS: I left the changing of the fuel filter till last.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    if you fill filter housing with clean fuel and crack the injector pipes of to bleed system it will start after 2to3 cranks
    Jul 2009
    Engine : 20 Dti
    sorry rapala we jumped in together
    No worries jonnyb. Its all helpful info.
    Jan 2010
    norfolk
    hi thanks for replies will do it all next week ,
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
