Results 1 to 10 of 13
Thread: Traction control light on (is it the CIM)
    Regular Member juggernaut's Avatar
    Rugby
    Default Traction control light on (is it the CIM)
    Still have this on going problem but not convinced it's the CIM (yet)
    When I start the car there are no warning lights, if I drive in a straight line, no warning lights, however as soon as I turn the wheel left or right the traction control light comes on and stays on and occasionally the steering wheel warning light will flash on and off.
    Similar applies if I just turn on the ignition and don't start the car, no warning lights until I turn the steering wheel left or right slightly. Is this CIM related or could it be something else?
    Are the tech 2 cleared CIM units on EBay worth purchasing? As £46 seems a better bet than £250+ especially if that's not the problem.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Check the ABS sensors on the wheels.
    Next time the TC warning light comes on, put an indicator (fully) on, let it flash about ten times, then cancel it
    If the indicator light stays on, then it is CIM failure
    Rugby
    Quote Originally Posted by Ian-Highlander View Post
    What would I be looking for?
    Quote Originally Posted by juggernaut View Post
    That's the process for checking a failed ABS module, where the ABS light comes on, or hub where both lights come on; doesn't apply in this case
    milton keynes
    90% sure it will be the steering angle sensor , which is part of the CIM
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    The simple reason I said check the ABS sensors is because I had this problem on my old 03 plate saloon. Traction control light coming on regularly usually when going round a bend. I tried all sorts of things and it turned out to be a bad connection on the ABS sensor on the wheel as the traction control system uses this to detect how the wheel is moving.
    Rugby
    Tried the above, both indicators and they can be cancelled normally without any lights staying on apart from traction control light.
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    My tc light was coming on from time to time. I had suspension fitted a month back, since then its been working flawless, no light on etc.
    Rugby
    Had a code reader on it today, looks like its a faulty CIM according to the fault thrown up
    Are the second hand "cleared" ones on Ebay worth trying out?
  1. ABS and Traction Control Light..
    By integrale in forum Suspension, Wheels & Brakes
    Last Post: 28th February 2012, 15:17
  2. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  3. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  4. no traction control light?
    By li4m in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2010, 10:42
  5. traction control light
    By chosen1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 09:02
vectra c traction control light stays on
traction control light stays on vectra
vauxhall zafira traction control light stays on
vauxhall signum traction control light
vectra traction control light stays on
04 meriva traction control light stays onmy traction control light flashing on vectra c vauxhall signum traction control light stays onvectra c no engine management light no start traction control light on cdc light ont 0pel insignia trection control problemszafira steerin wheel lights stay ontraction control light on in merivavauxhall zafira 2006 traction control light stays onvectra c traction control and stesting wheel lightzafira tc light onvectra comes up with traction control warning when starting cartraction control light on vauxhall merivavectra c cim failurevauxhall meriva traction control problemsvauxhall meriva traction control lighttraction control light comes on when turning zafira tourer meriva traction controlvauxhall omega tc light on no selector lightvauxhall meriva traction warningwhy.do traction control lights come on vauxhall meriva
