Thread: Heavy Steering....now I've got arms of steeeeeel!!
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    Angry Heavy Steering....now I've got arms of steeeeeel!!
    Hi all,
    Since owning the vectra when trying to turn the wheel it is incredibly difficult...as if no power steering whatsoever...and when turning a corner you have to go extremely slowly in order to turn the wheel in enough time. when I say extremely slowly i'm talking 10mph/15mph if turning into a road.
    So...
    I thought maybe it just needs the power steering fluid topping up or something....BUT IT HAS NO RESERVOIR
    and i've been told its electric.
    How can I remedy the problem? What is wrong?
    Thanks guys,
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Electro-hydralic.
    The reservoir is behind the driver's side wheel arch liner. Behind the headlight.
    Mine had identical symptoms, and a top-up solved it. Had to remove the wheel and liner to get the top off the reservoir, then feed a pipe into it from the top, and pour fluid in that way.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by tony-1977 View Post
    Electro-hydralic.
    There's a little filter in the top of the reservoir. Difficult to see, but just lifts out
    Mar 2011
    M4 Junc 12
    thanks for this guys....planning on doing it on Saturday....wish me luck!!
    Cheers,
    James
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by wingz123 View Post
    Cheers,
    James
    Good luck
    You'll only need to undo the 2 or 3 bolts toward the front of the wheel arch liner (once wheel off). It'll then pull forward enough to get your hand in and remove the cap and filter from the reservoir. I used a length of hose pipe (about 40-50cm), fed down from the top, into the reservoir, to top it up
    Mar 2011
    belfast
    if you find that the reservoir doesnt need topped up, try desconnecting the power connecters to the pump and cleaning the inside of them, that worked on mine, after i went and bought a second hand pump, which was none returnable. so now stuck with a spare one, LOL
    Chelmsford
    Surely a PAS problem should throw up an EML light and/or fault code...
    You got a code reader mate?
  1. Steering rack arms?????
    By veclee in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2013, 02:42
  2. Steering arms / tie rods
    By plasma in forum General Motoring Chat
    Last Post: 13th February 2013, 22:32
  3. steering rack arms
    By richje100 in forum Suspension, Wheels & Brakes
    Last Post: 7th July 2011, 11:24
  4. signum steering arms
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 20:51
  5. steering arms
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2008, 21:48
