Thread: torque 1st & 2nd gear 150 cdti
    preston
    Smile torque 1st & 2nd gear 150 cdti
    hi
    does anyone know if the torque is limited in 1st and 2nd gear in 1.9 150 cdti?
    if so, can it be adjusted in remap?
    cheers
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I believe it is limited on BSR remaps.
    Sodding Typical on Sea
    Car can reduce torque when cold to protect itself if that is what you mean?
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    Quote Originally Posted by Derek Mc View Post
    Like maximum revs are limited on a cold engine. 4000 max on a CDTI 150.
    preston
    i read somewhere that torque is limited in 1st / 2nd gears to protect drivetrain
    i just wondered if it can be tinkered with?
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Its not limiters in a specific gear. But its a limits in the map. This can be adjust in tha map and must be done if you want to tune your car. Look at the picture, left upper corner its the torque limits. This maps its not optimal så dont care about the value.
    Its normal to let the limits be on low revs or set then a bit higher, and set the limits high on higher revs. Or else dmf and other drivetrain part can snap.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    So on a remapped car, the torque limits at low revs would most likely remain unchanged, and altered higher up the rev range (which is where you would really want it)?
    Sorry if this seems an obvious question; on both Vectras I have had remapped, I noticed no difference low down after the remap, which would be a small price to pay if it kept your drivetrain intact.
    Aug 2010
    North of Norway
    There is not so much more power accessable, but some is it around 1000-1500 rpm. But its different from tuner to tuner where they set the limits at low revs. The most serious tuner I know he is very conservative and let the limits stay unchanged at low revs, especially cars that generally had problems with dmf.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. gear box oil cdti 150
    By dave r in forum Engine & Drivetrain
    Last Post: 18th May 2011, 00:43
  3. 2.2 dti torque vs cdti
    By daveypower in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2011, 07:40
  4. Replies: 3
    Last Post: 20th May 2010, 11:02
  5. Hmmmmm gear box torque!!!!
    By mikie in forum Diesel Engine related
    Last Post: 4th February 2009, 18:32
