Results 1 to 10 of 25
Thread: Error code P1191-52
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default Error code P1191-52
    Hi Guys
    Just got this code on the read out
    i had the spannerlight when i got home, so read them out and cleared them
    But this still remains, after the missus was out driving..
    P1191-52 Fuel Pressure System Malfunction
    It surly lacks power right now.. just came 2 minuts before getting home, and the missus stalled it when she was out driving..
    Those was new and wsa not there before the clear of error codes..
    U2103-00 No Communication with can-bus (high speed)
    U2105-00 Can-bus No communication with ECM (Engine control module)
    New high pressure fuelpump? if yes anyone know part nr. and how2 replace? (Z22YH)
    Engine : 2.2 Direct
    yesterday i picked it up from service.. he said he wouldt do anything about the fuel pressure system, as it wasnt there right now (i do understand him)
    but on the way out to dinner tonight the car stalled completly.. but it came back to life after 5 minuts..
    So now im back to maby changing parts.. but what to start with..
    Pressure sensor
    Pressure regulator
    High pressurepump
    (all 3 are connected to the fuelrail)
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Engine : 2.2 Direct
    I have read the "field remedy".. but mine is only periodic (spelled wrong).. but i have no way of checking the pressure.. (dont have a manometer to test with).. i do have access to a tester for the other tests..
    but dosnt help, when its only comming on every 3-5 time i drive the car.. (the sensor and regulator is easy to change.. about 5 minut job i think..). but still like 200£ (uk price).. for those to.. if its not all the way back in the lift pump in the tank..
    Engine : 2.2 Direct
    WEll just tried the sugegtion from the link..
    1: cant check.. dont have a manometer..
    2: well at idel it was about 4900 kpa (ustable...)
    3: well i read it wrong first... so i checked with the regulator power on.. there it said 2,4 V.. then i took the power from the regulator.. then the fun part began..
    now 2: was 380 kpa (acroding to my tester) and 3: was 0,9
    what to do now?
    Engine : 2.2 Direct
    Just changed the Fuel Pressure sensor and Fuel pressure regulator... So far no problems.. but before the change the car died 2 times on its way home..
    hopefully the 2 parts have cured the problem.. (could not determin wicht was faulty)
    Berks
    Vehicle : Back Signum Design
    Engine : z32se
    Unhappy
    Was Your engine noisy during that period, cause my one running like out of oil ??
    Engine : 2.2 Direct
    if my engine isnt at the "max" on the oil stick, my car is more noisy..
    And yes while the error was there.. it was lumpy, noisy, and drove like crap.. if it wanted to start.
    Jun 2011
    Elland
    This might help:
    http://www.ilexa.co.uk/forum/index.php?topic=24209.0
    http://www.vectra-c.com/forum/archiv...p/t-28293.html
    The HP pumps are repairable. If you can get parts.
    http://www.vectra-c.com/forum/showth...ht=repair+pump
    TIS 2000 gives:
    The following test steps must be performed in the given order. If a fault is found in one test step, the subsequent test steps can be skipped.
    • Execute field remedy No. 1614
    • Turn ignition OFF and ON
    • Delete trouble codes
    • Drive the vehicle in different driving conditions (engine speed and engine load conditions) over a considerable distance. Pay attention to unusual noise and other system irregularities.
    • Read and record again trouble codes including status after the test drive.
    Of which the latter blue bit is
    Function Checks
    • Check Engine Oil Level
    Important:
    The fuel system is very sensitive. Work should be done with high cleanliness and care. Air in the fuel system can cause damage to the high-pressure fuel pump. That's why the vehicle must never be driven till the fuel tank is empty.
    • Check fuel tank for correct fuel sort content
    • The fuel reserve must be greater than 5 L
    • Check the concerned system for leaks
    • Check connected hoses and tubes for kinks, damage etc.
    • Point of breaks / scuff marks at the fuel or injection lines
    • Check connections of the fuel lines (Quick Fittings).
    • Check condition of the three-way fittings.
    • Check the correct fitting of the connections and sealing.
    • (use only sealing, that is approved by the vehicle manufacturer)
    • Check tightening-torque of the hollow screws.
    • Check fuel filter
    • Plugging, leakage, air or water in fuel system
      Check for pressure decrease in the fuel supply section.
    After successful test/fault repair proceed to the next test step
    Engine : 2.2 Direct
    And the error code is back.. and virtualy undrivable... took like for ever to get home from holliday... 350 miles..
    and was not allowed over 3000 rpm (most times less) then it went like on 2 cylenders.. and max speed of 60 mph..
    Damm it took forever.. what should have taken 6 houres.. took 9½ hour.. same errro as originally..
    Should i go right off after the pump or the regulator ?
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. The dreaded P1191 code!!!!
    By OggieJMX in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2010, 16:55
  3. 2.2 Direct (Z22YH) - P1191 Error
    By johnmac in forum Engine & Drivetrain
    Last Post: 2nd April 2010, 00:40
  4. Spanner Light with P1191 fault code?
    By simp_2.2sri in forum Vectra C / Signum Troubleshooting
    Last Post: 16th October 2008, 20:14
p1191
p1191 signum
p1191-52
OPEL P1191
vectra c p1191
Opel DTC P1191-52
p1191 opel vectra
p1191-52 vectra
fault code p1191
2.2 direct p1191-52
u2103-00 opelp1191 vectra 2.2p1191 vauxhallp1191 opelp1191-52 fault codevectra 2.2 p1191p1191 vauxhall fault codekoda napake 405 opel vectra cOpel DTC P1191-5aP1191-5avauxhall vectra 2.2 se p1191 fault codeopel vectra c 2.2 direct z22yh falloVauxhall DTC P1191-52Vauxhall DTC P1191-5ap1191 opel signum
