Thread: Drivers Electric Window Switch
    Belfast
    Default Drivers Electric Window Switch
    As per title, are these hard to remove? (without the usual gouges out of the surrounding doorcard!)
    the drivers window switch seems to be on the blink, as it only works if you leave it depressed for maybe anything up to a second or so.
    It looks like these are only available as a whole unit, so i'll pop the old one out and replace if necessary. all the other window switches seem to be working ok
    anyone any pointers?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Pop it out (just stick a blade carefully down the side) and then take it apart and clean the contacts. 30 second job, there's a howto on the forum somewhere if you get stuck. You shouldn't need to replace it.
    Regular Member Innes's Avatar
    Plymouth
    Its a common fault and can be repaired.
    Here is the how2:
    http://www.vectra-c.com/forum/showthread.php?t=92625
    Belfast
    cheers guys, thats gotta be worth a try
    Belfast
    done! followed the how2 and working perfect now!
    used acetone to clean the contacts. they looked surprisingly clean although once stripped out of the housing. funny how a tiny film of grime becomes a real pain in the rear!
    many thanks for the pointers guys
    £30 saved :-)
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Glad to have helped
    Apr 2011
    blackpool
    Just followed this for my passenger side switch, brilliant thankyou.
    Sep 2011
    County Donegal
    rolleyes
    Quote Originally Posted by Threepiers View Post
    I had same problem on my vectra C 1st gen now same on my 06 is happening so gonna clean contacts
    you will need to remove switch and clean the copper contacts on the switch board as they tarnish due to I assume condensation once that's done they should work grand but be careful not damage
    HOPE THIS HELPS
    Radioshuk
    Jan 2016
    Bandon
    Trim : 1.6
    Engine : 1.6
    Year : 08
    Just did this and it worked first time. Thanks, GREAT HELP Innes.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Holy thread resurrection, Batman !!
  1. help needed electric window switch drivers side vec c
    By readbri in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2013, 12:03
  2. Electric drivers window not right
    By big nath in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2011, 11:44
  3. Drivers Electric Window Switch
    By Damian in forum Parts for sale
    Last Post: 6th June 2008, 17:05
vectra c window switch removal
vectra c drivers window switch repair
vauxhall vectra electric window switch removal
vectra c window switch problem
how to remove vectra c drivers window switch
how to remove vauxhall vectra c window switch
how to remove vectra c window switch
how to remove vectra window switch
vectra c window switch replacement
vectra window switch removal
vauxhall vectra window switch not working
vectra c passenger window switchvectra c electric window switch removalvectra c electric window switchvauxhall insignia window switchzafira electric windows not workinghow to remove electric window switch vectra c04 vectra drivers side window switchesvauxhall vectra window switch 03corsa c window switchopel vectra c right window switchvectra window probleminstalling vectra c window switch
