Results 1 to 10 of 11
Thread: P0301 code only and V6 3.0cdti
    Stoke
    Default P0301 code only and V6 3.0cdti
    Have got a 04 plate, Y30 engine, done 120K, this code (P0301, cylinder 1 misfire) has been present on and off for about 20k, 18 months, including before and after service (inc fuel filter change)
    More recently the car goes into limp mode after hard acceration only, at 3000rpm (more gentle accel ok). No new codes other than P0301.
    Any ideas?? I have had various suggestions from garages, but i dont want to waste tons of cash chasing different theories.
    Any suggestions appreciated.
    Stoke on Trent
    Im going to put money on dodgy injector!
    Stoke
    Cheers, i was thinking of that being first option of taking them out and getting them correctly cleaned.
    Stoke
    But no judders or loss of power noted, runs as smooth as it also has done, or does that not matter?
    Belfast
    most cost effective way would be to try moving the cyl 1 injector to cyl 3 (in the same bank). If the code follows it to cyl 3 then you'll know its the injector at fault.
    pain in the rear getting to the rear bank in the y30 though.
    Stoke
    thanks for this.... will try
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    My old 3.0 never gave a fault code when the injectors were fuc*ed. Maybe you have an electrical fault, giving false data to ECU, which in turn delivers too much/not enough fuel to cylinder number 1. My car was running like poo, which yours isn't.
    Quote Originally Posted by med09 View Post
    Who is reading and supplying this code?
    After reading has it been deleted?
    Stoke
    I am, cant remember whether i had deleted it but read it 18 months ago and again recently, also a independant garage came up with the same.
    So it could be electrical? but why does it occasionally limp (but will do over 4000rpm with little power) on hard accel until engine switched off and reset or is the EGR valve sticking?
    This was a bit stickey at about 70k then I read this forum that suggested to drive like i stole it on a reg basis, it then was fine.
    If the EMS receives no response, or a response outside tolerance, from a sensor it records it as a fault
    Depending on the sensor and threshold the EMS then puts the engine into "safe mode"
    When you switch the engine off, and leave it for about 2 hours, then EMS "resets"
    On restarting the engine assumes there are no faults, but the previous faults remain recorded
    It is not good to go above 3000rpm in "safe mode"
    After about 20 starts and no repeat faults the previous fault is then deleted
  1. What is causing P0301 - Misfire no 1
    By myveccy in forum Y & Z30DT Specific
    Last Post: 17th February 2013, 09:16
  2. Z30DT and P0301
    By LeeU in forum Engine & Drivetrain
    Last Post: 6th April 2011, 13:49
  3. P0301 & P0304 misfire
    By tridley in forum Engine & Drivetrain
    Last Post: 27th September 2010, 00:06
  4. Fault code P0301 on 3.2 HELP?
    By jamesr in forum Engine & Drivetrain
    Last Post: 26th February 2009, 17:59
  5. error code for a 3.0cdti
    By bruceybonus in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 09:56
vectra 3.0 cdti 0301
