Thread: lowering question
    Regular Member davidmcd2002's Avatar
    Feb 2011
    Nottingham
    Cool lowering question
    Hi all, just a quickie (I hope). My siggy sits higher at the rear than the front (common with all). If i then use 30mm lowering springs does that mean that the back will still be higher than the front but just 30mm loer tha standard? Also, are there any springs that will lower to 40mm or 45mm all round? have not found any online tha do not require coilovers.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    PI do -45mm springs (for the Vec anyway, should do some for the Siggy).
    Feb 2011
    Nottingham
    hmmmm... can't see any 45mm all round lowering spings on the PI website, but thanks anyway. Have sent them an enquiry just in case
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by davidmcd2002 View Post
    Very true, they only seem to list the 35/25 kits, hmm... wonder if a Vectra kit will do for the Signum..?
    Regular Member neilb1's Avatar
    Feb 2011
    wigan
    I will be interested in this as i am fitting some 18's soon
    Feb 2011
    Nottingham
    PI have confirmed that they only do 35/25mm kits for the siggy. Doubt that Vectra springs would be the same due to the siggy being more an estate than a saloon (and load difference), but I'm sure someone else can expand on that.
  1. Lowering Question?
    By Del101 in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2013, 18:28
  2. camber question after lowering
    By Mads in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2011, 13:24
  3. lowering question
    By MSharkey in forum Styling
    Last Post: 15th October 2009, 11:22
  4. Lowering Question
    By Genterz in forum Handling & Braking
    Last Post: 18th September 2008, 13:45
  5. Another lowering question !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 28th March 2008, 12:34
