Thread: swirl bar off - refitted but think its better off?!
    Mar 2011
    STOKE-ON-TRENT
    Default swirl bar off - refitted but think its better off?!
    Had a fe posts recently re the 150bhp engine. I had a cam belt failure and during the process of seeing what the issue was noticed the swirl bar off.
    Have car back (finaly) and yesterday attempted to refit the bar. The car in stopped position has the 1 2 and 4 flaps loose and at various positions, the third was stuck at 10 o'clock.
    Got the bar to go on with the fix on this site but using number plate plastic screw covers, perfect fit, just pop on and have enough grab to stay on.
    Went to drive car and low end power is all gone, decided to take bar b ack off as I think its been off for 12 months + and performace was much better.
    Not sure if it may be that 1 2 and 4 flaps are flopping open closed as they need to without the bar, or if its a case of number 3 flap being stuck with its motor, perhaps by fixing all in the 10 o'clock position they are all open or all closed and choking the engine?
    Any ideas?
    Engine : 1.9 CDTi
    If the 3rd one is stuck as you say it will be keeping the others at the same angle with the bar on.
    Only down side I can see is number 3 will be getting a different mixture and could be carboning up more than the other 3.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The missus' car (CDTI 150) has the swirl bar off. Flap 3 moves freely, but the others are seized. I've pushed them into the open position, where they've stayed for 29k miles now, and had no issues at all. No sluggishness, no excess smoke... I intend to get my money's worth from this manifold It's done 122k miles now
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by tony-1977 View Post
    Just wait when the bearings finally loose their battle with the partial vacuum being created in the manifold, then they get sucked into the engine. With a bit of luck - as they are plastic, the valves and pistons may smash them up. On the other hand, the flap may get it's own back and cause some serious engine damage.
    Before anyone says it, leaving the flaps open when the rod is off is not the same as a manifold with properly working swirl flaps. The is due to the weaker bearings on the old manfiold not being able to support the swirl flaps any longer so they give way in time.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Bristol
    Just give up, the manifold will have to be replaced just had mine done under warrenty It' now like a new car.
  1. Swirl bar
    By 1 hammer in forum Diesel Engine related
    Last Post: 24th October 2012, 21:58
  2. Replies: 9
    Last Post: 13th May 2012, 23:31
  3. DRLs REFITTED.
    By frasedeb in forum Styling
    Last Post: 12th March 2012, 16:28
  4. swirl or not to swirl
    By lesron in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 19:53
  5. Exhaust refitted into bumper
    By lee_eardley in forum Styling
    Last Post: 15th September 2007, 09:20
