Results 1 to 10 of 11
Thread: upping the boost??
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Default upping the boost??
    how much boost is the 2.2 dti engine running standard? 0.6? has anyone upped the boost to say 0.8? how does the car perform?
    Regular Member Innes's Avatar
    Plymouth
    How do you up the boost without changing the turbo?
    Mar 2011
    Donegal
    you can up the boost by adjusting the actuator(waste gate control valve) on the 2.2 it seems like an adjustable one, so you just screw it abit, but youd need a boost gauge to be sure you dont adjust to far. im not sure what is a safe level. you can buy an mbc (manual boost controller) also id imagine, im new to the diesel scene but ive had a petrol turbo car in the past.
    There is many ways to up the boost on a turbo car ebc (electronic boost controllers)
    mbc (as i mentioned)
    and adjustable actuators (which id prefer)
    Plymouth
    I thought that just controlled WHEN the boost kicked in more than adding actual boost. I'm sure someone will be along to confirm. I've got a feeling John Robertson adjusted his to REDUCE boost as he kept going into Limp-Home Mode. I posted a thread about a LHM issue I was having HERE.
    I never got around to adjusting the arm as the LHM issue hasn't really occured since I squirted the Actuator rod arm in wd40.
    Mar 2011
    Donegal
    see im sure it controls how much boost before it opens, which would be upping the boost, i wasnt sure if it would go into limp mode, but alot of turbo cars have a factory fuel cut, when the ecu sees the car over boosting it stops it by fuel cut, then you would get a fuel cut defender to stop this fuel cut so you can run more boost but you would neeed supporting mods also., id say the limp mode in this case would be the same, but am not sure as its my first diesel, but there must be away to stop the limp mode so that you can run more boost
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    i think i will be keeping an eye on this 1
    Mar 2011
    Donegal
    so any1 have any ideas?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Only way you can do it is with a re-map tbh, shortening the actuator will simply show overboost and throw the car into limp home mode
    Mar 2011
    Donegal
    so theres no way of stopping the limp mode, can anything be wired into the ecu to stop this, i see from your previous posts a remap wouldnt be the best thing for the dti with the fuel pump, i like the idea of the tunning box you have
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    TBH the box is a great little thing. The standard boost is more than enough on the dti to put a smile on your face.
    The re-maps are fine but if you should be unfortunate enough to have pump failure then you'd need to get the new pump re-mapped too
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
vectra dti adjusting wastegate site:www.vectra-c.com
