Thread: Rear tyre wear
    Regular Member Geoff644NI's Avatar
    Cloughmills,Northern Ireland
    Default Rear tyre wear
    Having very excessive rear tyre wear, and quite bad tramlining. Have changed the boomerang arms (upper rear control arm) and have 4 wheel alignment done every 6 months. Had the rest of the bushes checked over and they're fine, the car is lowered 35mm on koni springs and 19" wheels. Anyone any suggestions before im going to have to replace the whole rear suspension
    With the lowered springs has the camber been checked and adjusted?
    West
    as above, the motor should go for a full geometry set up once lowered
    The 4 wheel alighnment has been done every 6 months to ensure it is correct, this includes rear camber and toe in/out, an all readings are within tolerance, although camber is adjusted at it's maximum.
  1. uneven tyre wear on rear
    By croado in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 19:12
  2. Which rear part causes tyre wear?
    By stuartbat in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 22:19
  3. Rear Tyre Wear
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2008, 22:20
  4. Rear tyre wear
    By nhoj in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2008, 15:10
  5. Rear tyre wear Vecta 03
    By gordonc in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2007, 16:52
