Results 1 to 10 of 14
Thread: HEY LOOK!! Plugged my car in and got these codes....(cyring) please help!
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    Unhappy HEY LOOK!! Plugged my car in and got these codes....(cyring) please help!
    Hi all,
    I got my car on Friday and plugged it in today - Can i just say thank you Mark for offering to plug it in for free for me...my friend said their friend had a workshop and had a computer.
    PO120 - Accelerator Pedal Position
    PO220 - Accelerator Pedal Position 2
    PO704 - Invalid Signal from TCM (Transmission Control Module)
    PO070 - Ambient Air Temperature Sensor - wiring or sense malfunction
    PO380 - Glow Device Circuit (Glow Plugs)
    PO195 - Unknown Error
    PO234 - Boost Pressure Control - Negative Deviation
    Can anybody help me with this at all?
    Thank you in Advance...
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    stick some glow plugs in and fix the boost issue and i wouldnt worry about the rest lol
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Po234 is your boost sensor ,probably just needs a clean , remove and spray with carburretor cleaner if still dirty just agitate with small paint brush , nothing harsher it can be easily damaged .
    P00070 is worth checking out as it is linked through your thermostat to the electronic choke
    P0380 as other,s have said probably just a glow plug going faulty easy enough to check and change
    and still loving it
    Mar 2011
    M4 Junc 12
    thanks guys...going to change the glow plugs this weekend and bleed the clutch as it feels soggy, change the fluid in the gearbox and clean the egr valve....
    can anyone send me any pictures at all on how to clean the boost sensor please.
    also....when you try and turn the steering wheel quickly its supposed to have power steering but it is extremely heavy and you can't turn quickly....does anyone know how to sort this at all? I thought it might have been low on power steering fluid but apparently it doesn't have one and its all electronic?!?!?
    Cheers!
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Engine : 2.0DTi
    Mileage : 73350
    James enclosed some pics for you of egr, manifold and boost sensor in this thread , just remove the 4 bolts in the top of the manifold detatch hose connection and disconect electrical connections to sensors.
    Boost sensor held in by single bolt and can then be just pulled of only retained by rubber gromet just spray sensor with carb cleaner and if badly cruded up then just lightly agitate with a small paint brush
    DO NOT remove the other sensor thats your tps sensor and if you misalign that its an expensive fix
    http://www.vectra-c.com/forum/showthread.php?t=71985
    and still loving it
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by troutybrown View Post
    That's a 1.9 CDTI m8.
    Gazza4
    Mar 2011
    M4 Junc 12
    Yeah I noticed that mate....slightly different layout on mine...I've got the 2.0dti engine...
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    oops
    Regular Member vectraboyy's Avatar
    Quote Originally Posted by wingz123 View Post
    What year?
    Is it the Y20DTH
  1. plz help with codes
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 1st October 2012, 21:02
  2. towbar electrics, something already plugged in?
    By Adamdavi3s in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 18:10
  3. codes
    By mauricemersey in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2011, 17:22
  4. codes
    By Vectra King in forum Petrol Engine related
    Last Post: 3rd February 2011, 17:45
  5. DPFE Sensor off or plugged 1405
    By skinnyseand in forum Vectra C / Signum Troubleshooting
    Last Post: 29th August 2007, 08:36
