Thread: 2006 Vectra 1.9 CDTI 120hp Glow Plugs
    Mar 2011
    Lisburn
    Exclamation 2006 Vectra 1.9 CDTI 120hp Glow Plugs
    Would any of you members out there who own vectors or have done In he past please tell me what tools are required to change the glow plugs. The cars Very hard to start and I am lead to believe new glow plugs are the answer. Thanks in advance
    banbury
    2004 1.9 cdti 120 signum.
    just done my glow plugs after 110000 miles using good fuel always. took me 3hours to do. you need torx,allen keys 1/4" socket set with 10mm deep socket with wobble bar and extensions. egr had to come off, used wynns egr3 spray to free one tight plug and clean egr whilst off, removed boost sensor and engine cover. needle nose pliers needed to remove connectors and refit them, a good light also needed, very fiddly but as a retired engineer possible without belting the wife! if you aint confident with tools dont attempt it.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Usually if the glow plugs are faulty then the glow plug light on the dash will stay on for a few minutes after starting, possibly should also have a trouble code
    Aug 2010
    Leeds
    As this was started in March 2011 im sure he has done it by now.
  1. 1.9 CDTI 150 Glow plugs....Help???
    By bogjust in forum Engine & Drivetrain
    Last Post: 28th January 2013, 12:20
  2. Glow plugs - 120 cdti (2004) vectra
    By baldieone in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd March 2011, 18:48
  3. Glow plugs on a CDTI 120
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 5th November 2009, 22:39
  4. Glow plugs 1.9 cdti 120
    By mark230678 in forum Parts for sale
    Last Post: 3rd July 2009, 21:40
how to fit glow plug leads on a vector c cdti
how to remove glowplugs leads vectra 1.9cdti
