had a valve done on number 2 on vectra and now all back together ect and it wont rev over 4000 revs,what could this be?cannot be because we ran out of fuel can it
it could be a blocked filter or the fpr is going or you may not have timed the engine 100% correct
im sending it to go on machine hopefully theyll sort it,can it be the timing?stopping it going over 4000 revs
yip if its out you sure its not in limp mode? is the eml showing?
whats eml
yes thats on
Its in limp home mode then. It stops the engine revving over 4k rpm to prevent damage.
so what do i do to get it out of limp mode
to find out what is triggering EML and limp mode, you need to get codes read. This can be by a garage, a cheap code reader off e bay, or try pedal test:www.vectra-c.com/forum/showthread.php?t=81742 Then you can look codes up on internet or on here. They will hopefully help pinpoint problem.
Obviously the recent work is a good place to start.
