Results 1 to 10 of 14
Thread: another problem
    Regular Member the fisherman's Avatar
    manchester
    Default another problem
    had a valve done on number 2 on vectra and now all back together ect and it wont rev over 4000 revs,what could this be?cannot be because we ran out of fuel can it
    Jan 2010
    glasgow
    it could be a blocked filter or the fpr is going or you may not have timed the engine 100% correct
    manchester
    im sending it to go on machine hopefully theyll sort it,can it be the timing?stopping it going over 4000 revs
    Jan 2010
    glasgow
    yip if its out you sure its not in limp mode? is the eml showing?
    manchester
    whats eml
    11 Post(s)
    Quote Originally Posted by the fisherman View Post
    whats eml
    Engine Management Light.
    manchester
    yes thats on
    Barrow In Furness, Cumbria
    Its in limp home mode then. It stops the engine revving over 4k rpm to prevent damage.
    manchester
    so what do i do to get it out of limp mode
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    to find out what is triggering EML and limp mode, you need to get codes read. This can be by a garage, a cheap code reader off e bay, or try pedal test:www.vectra-c.com/forum/showthread.php?t=81742 Then you can look codes up on internet or on here. They will hopefully help pinpoint problem.
    Obviously the recent work is a good place to start.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
