Thread: Car Trouble
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default Car Trouble
    Hi guys Few problems with my car hope someone can help,
    its a Y22dtr Auto 2003
    Car starts fine
    Smoke a little bit white smoke.
    When i put it into D it takes approx 5 - 6 seconds before it "jumps" into gear (reverse is fine)
    When i hold my foot on the brake in D the car trys to stall and chucks loads of smoke out the exhaust and then it goes into Neutral on its own while saying its in D then i have to knock it up to N and back to D to get it going.
    acceleration on the car is good very responsive at times sometimes it can be hesitant. i put a tenner in and get only 30 - 35miles round town
    and sometimes when driving at a constant speed the car will judder on and off on and off then when i remove my foot of the acceleration peddle or accelerate more the judder (vibration) will go its weird to explane but its not a constant vibrate/judders its more on off on off like a phone ringing if that make sense.
    I have put on a NEW maf and a second hand EGR witch removed my old EML for EGR.
    No EML on except a code stored
    B3601 - Key Capture Relay Circuit Malfunction
    (04) - Present
    thanks in advance
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    TIs says that the key capture relay fault codes is;
    The resistance of the lifting solenoid is greater 110 Ohm
    what ever that is i dont know
    but i dont understand what its talking about.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    bump
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    bump any one help?
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    3 Thread(s)
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2 v6
    Mileage : 69,000
    could it be the gearbox? how many miles has the car done?
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    107000 just fitted an external cooler and done a fluid change no water in the box
    Regular Member Signum Dek's Avatar
    South Yorkshire
    The auto gearbox does drop into neutral by itself, if you pull up with your foot
    on the brake, but should re-engage when you take your foot off the brake, and
    drive away normally.
    South Yorkshire
    Sounds like the gearbox is short of oil, did you check the level after driving for 15 min and with the motor still running ?.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    yep the gearbox oil is on the mid line when one HOT when engine is at full running temp.
    Its had nearly 5 liters of fluid in it after dropping it from the plug and adding external cooler.
    I can 100% say its got enuff fluid.
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    nice to know about the drop in and out of gear but again still takes around 5 - 6 seconds to engage into D not matter what way i do it.
    and gearchange can be a bit laggy somtimes when warm can be really bad going up and down. Reverse tho always seems spot on
  1. What next Fan trouble
    By nokiaman1978 in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2011, 20:00
  2. Fan trouble
    By xf8u39 in forum Bodywork & Interior
    Last Post: 18th March 2011, 19:06
  3. Im having trouble with my
    By dannyjpuk in forum General Chat
    Last Post: 9th June 2010, 16:42
  4. Car trouble
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2009, 18:26
