Results 1 to 10 of 19
Thread: I know, LED side lights again
    Oct 2006
    southampton
    15 Post(s)
    Default I know, LED side lights again
    Has anyone on here used these to cancel out the problems with led sidelights throwing up faults or pulsing.....
    Oct 2006
    southampton
    15 Post(s)
    Bump
    Jul 2009
    The Rift, Cardiff
    They'll stop the error warning but there's no mention of them stopping the flashing.
    Hard wiring additional 501 holders from the dash illumination circuit is simple, cheap (or free from a friendly scrapy) and easy to put back to standard. You also get lights on with key press.
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by ChrisBilly View Post
    Dash illumination, explain if you dont mind, want the LEDs in there now....
    Oct 2006
    southampton
    15 Post(s)
    has anyone used these one to get rid of the strobe effect....
    Jul 2009
    The Rift, Cardiff
    I used the cig lighter illumination wire, yellow/grey, run the wire through the gromet next to the pollen filter to the headlights for the new 501 holders. The original bulbs and holders are wrapped in foil and tucked away behind the headlight units -this stops the bulb warning and they can be replaced if they blow. Leemarksmith has done a how2 including switches but as he memtons you can wire them diectly, bypassing the switch.
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    so ur saying in leaving the old holders in the wiring with normal 501's in then add a NEW holder with the LED 501 thus preventing the car from finding a error
    Jul 2009
    The Rift, Cardiff
    thats right mate. I've only had to replace one of the original bulbs once since doing this mod sometime last year, and they were over a year old then, so foil wraping them dosn't sem to have an effect on lifespan.
    Oct 2007
    Shropshire
    Remember to be careful where you connect too if you take a feed from the dash lights else you will also have a diming control lol!!!!!
    Oct 2006
    southampton
    15 Post(s)
    My ciggy socket hasnt got the illumination so, how else can this be done, need LEDs in as they look so much better imo....
  1. side lights and number plate lights
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 19:59
  2. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  3. led dash lights and side light running lights
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 21:21
  4. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  5. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
