Thread: Error codes p1525 & p1550
    London
    Default Error codes p1525 & p1550
    I just had my car fully serviced and MOT'ed last month. Today my battery dies so I popped a new one in, lovely. I decided to do the old pedal trick to see if I had any faults and I do
    p1525 & p1550
    Now I have found out what they mean individualy via this site but can anyone tell me what they would suspect the fault to be with these 2 codes collectively. The car has no other indications (no spanner light {yet}). It is a 1.8 petrol 54 plate life model.
    Thanks for your replies.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    From the the following:
    http://www.edgeproducts.com/product_...cle-pdf-40.pdf
    P1525 - Throttle Body Service Required
    However I can't find the other code, maybe worth a recheck there.
    Gazza4
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    P1550 electronic throttle control engine stop/management
    and still loving it
    London
    thanks for the replies, I got that. What I want to know really is what is the actual fault? Is it a part needed or a clean up? what sort of costings and what are the long term effects if not fixed ASAP.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Honestly, if you only know this by reading the codes with a scanner or pedal procedure and running isn't affected, I'd wait until the MIL light or Spanner light comes on.
    I check for codes regularly and sometimes the is a code there ( P0536 is a common cruise control one) and I'd had another involving MAF and Lambda sensor.
    If these are not serious enough to light the MIL light on the dashboard (engine light), it's usually a sensor just thrown a wobbly or a situation that's happened to cause it to light.
    I'd personally wait to see if it clears. If the problem gets worse and the MIL light comes on and the codes are still present, that's the time to do the job.
    I'm sure there's a HOW2 on her how to clean the throttle body!
    May 2007
    And here it is LINKY.
    As HOW2 says, theory should be the same across most engines.
    London
    Default top tip
    Quote Originally Posted by John C S View Post
    Thanks for that, really appreciated. Top tip though on letting the car tell me when it needs fixing as apposed to be being paranoid. Im sure if I was to read the fault codes daily I would be panicking over nothing. See as that How 2 is so easy I may just give it a bit of a clean though. For now im gonna play dumb until the little spanner or engine light comes on, what I don't know won't hurt me
    May 2007
    Quote Originally Posted by ryantcb View Post
    Exactly. If you didn't know that procedure or code reader, you'd think nothing was wrong!
    I expected to need a new O2 (lambda) sensor in Jan 2010. That fault soon cleared and have been through two MOT's since with clean emissions.
    If yours is a late 04 1.8, you may not have an EGR system and therefore, as carbon and soot won't be being re-combusted through the engine.
    If this is the case. you throttle body won't be that mucky!
  1. (error codes)
    By tomo610 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2012, 20:07
  2. error codes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 20:33
  3. 3.2 error codes help please
    By gibsonk in forum Engine & Drivetrain
    Last Post: 28th January 2012, 13:03
  4. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  5. error codes
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 13:27
p1550 vauxhall
p1525 vauxhall
p1525
P1550 Electronic Throttle Control Engine Stop error brain failure
p1550
OPEL P1550
p1550 vectra
p1550 opel vectra c
p1525 opel
vauxhall fault code p1550
Opel P1525
vauxhall fault p1525
P1525 vectra c αιτίες
opel zafira a hiba kodok P1525
p1525 code vauxhall vivaro
P1525-0 trouble codes
vauxhall code p1550
astra dtc p 1550 1.8
p1525 opel astra
trouble code p1550
opel vivaro cruise control error p1525
p1525 vauxhall vectra 2.2
p1550opel vectra c
p1525 fault code vauxhall
p1550-B code Opel PDF
