Thread: Update update update update update update
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    Unhappy Update update update update update update
    Hi all,
    You may have seen my threads about my clutch and not being able to get the car into gear....
    well....I went over to the car tonight as I needed to get it back to my house so took a train over.
    I then approached the car and started her up....WEIRDLY...it went into gear and I was able to drive off...only problem was the handbrake was seized on ( i could feel the resistance)
    So i drove off and for fear of not being able to get it into gear on my journey home and being stranded somewhere else I took the motorway.
    Driving down the slip road all was fine then onto the motor off I went...As I was accelerating up through to about 80 mph....It eased off without me doing so as if you have your foot right down to the floor and your are running out of petrol/diesel. Do you know what I mean? As if the acceleration isn't constant. I wasn't out of diesel...I had a quarter of a tank left....
    Nonetheless I carried on and the car would go no faster than 75mph at a push...
    Came off the motorway at Junc 12 of M4 and as I accelerated away from the traffic lights the car will not rev above 3000rpm....
    Struggled to get up a steep hill in Calcot but got there in the end and now the car is parked outside....First thing I have done is report this back on here to see if anyone knows what the hell is going on?!?!?!
    PLEASE HELP!
    Regular Member sebadee's Avatar
    macclesfield
    Any spanner lights on the dash sounds like ur car went into limps home mode but I may be wrong
    Mar 2011
    M4 Junc 12
    No mate....no spanner lights on the dashboard...yeah I thought it might have.....
    man i only bought this car on Friday
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Take it back for a refund
    Mar 2011
    M4 Junc 12
    No chance of that mate...
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    im not very good with diesels but have read quite a few threads that have said the same im sure some one will know the fix
    it might be egr from memory but look in the old posts HTH
    Mar 2011
    M4 Junc 12
    Yeah...what's the function/purpose of the egr valve...what does it do?
    Sorry I'm not too technical myself
    Thanks,
    James
    Aug 2010
    Luton
    look in the how 2s there is one for cleaning it
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    With you loosing power while cruising , i am wondering if your turbo is not spooling up , now this can be your intercooler hoses , your vacuum hoses the turbo itself , failing that maybe as others have said egr blocked up with soot would pull the power down , but most if not all of these would bring up the spanner light on your dashboard .
    To start your checks what does the car tick over like is it a constant speed or does she hunt up and down on the rev,s , if thats ok get some to sit behind the wheel and rev the engine meanwhile you look for any sign of air escaping anywhere on the inter cooler hoses also check your vacuum hoses for signs of cracks or perishing around the connectors if still no luck there then we will think of other things like egr or boost sensor to check and clean
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Did you manage to disengage the handbrake
  1. 3.56 ps3 update
    By signumturbo04 in forum Games Room
    Last Post: 6th March 2011, 21:05
  2. An Update :)
    By DarylAAS in forum Insignia car chat
    Last Post: 18th January 2011, 20:52
  3. The vec bus- update
    By Dose in forum Gallery
    Last Post: 10th May 2009, 00:45
  4. Update on car
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2008, 21:43
