Thread: spanner light - no turbo?
    Regular Member John3v36's Avatar
    NI
    Question spanner light - no turbo?
    just troubleshooting here. the very odd morning going to work the spanner light comes on on the dash and the turbo does not kick in (2.0dti), and i can very slowly make it up to the usual 70-75mph. then when im coming off the motorway it goes off and the car works fine - turbo working etc.
    what could this be? earth? connections ??
    Engine : 1.9 CDTi
    Sounds like classic egr problems
    Aug 2010
    Blackwood
    i had the same problem. my 2.0dti went into limp mode, after a few times of this the engine management light stayed solid and the spanner light no longer flashed up but the car would still go into limp mode.
    RAC plugged in their machine & it showed mass air flow malfunction.
    tok it to a garage, they wanted £250 to fix this. bought a sensor for £75 just before i was going to fi tit, took the engine cover off and seen to inch long splits in the intercooler pipe. wrapped aload of duct tape around it & it worked until i bought a new pipe off ebay (£50 instead of £100 from vauxhall)
    have you checked the pipes?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    That's limp mode mate. I had the MAF off when i used the 10k boost on the V6 and had the same symptoms. No turbo (seemingly) low power, limited revs.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. 1.9 CDTI Turbo Whine and ECM02345a spanner light + limp mode
    By wakey1512 in forum Engine & Drivetrain
    Last Post: 4th August 2012, 20:18
  4. Help, spanner light on and no turbo!!!
    By stiggy in forum Engine & Drivetrain
    Last Post: 29th May 2012, 21:56
  5. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
vectra c diesel spanner light and no turbo
