Results 1 to 3 of 3
Thread: Oil Level Warning Light After Oil Change?
    Midlands
    Thumbs up Oil Level Warning Light After Oil Change?
    Hi There Chaps.
    First post but long time browser!
    I did an oil change on my 2.0 dti Vectra-C a couple of weeks ago. Topped oil back up to correct max mark on dipstick, but intermttently the oil level warning light comes on. If I switch off and back on again the light goes out for any time up to around 30 minutes but will come back on again. It never happened before I did the oil change, and I'm pretty sure I drained a lot more oil out than I put back in, but I am 100% sure that the oil level is fine going by the dispstick. When I check I make sure the car has not been running for at least 5 minutes and the car is level etc. etc.
    Has anyone else had the same problem or have any ideas what might be wrong. I know its nothing catastrophic as I've done about 800 miles since the change and as long as the oil pressure warning light does not iluminate, no damage is happening to the engine.
    Any help really appreciated.
    Thanks.
    Carl.
    Apr 2009
    Cheshire
    I have exactly the same problem, does anyone know how to fix this?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    what oil did you use?
  1. Oil Level warning light
    By Bren G in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2012, 21:55
  2. Intermitent Oil Level Warning Light - 2.8 V6
    By luke4487 in forum Engine & Drivetrain
    Last Post: 22nd May 2011, 15:06
  3. Coolant level warning light
    By phils in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2011, 21:22
  4. Oil Level Warning Light issue
    By Blagmeister in forum Engine & Drivetrain
    Last Post: 14th March 2010, 18:23
  5. Oil Level Warning Light
    By Gogs67 in forum Engine & Drivetrain
    Last Post: 16th November 2009, 20:25
