Thread: shows how good this site is
    Thumbs up shows how good this site is
    while searching for parts for my sig ( y30dt ) i came across a thread on website called boards.ie
    not sure what its about but below is what was copied from a thread on changing a 1.9cdti water pump
    General concensus on the vectra c owners club is 40k miles or every 4 years without exception on every model. They say anything over that is a gamble. I trust what they say as theres not much they don't know about this model.....must book mine in then
    so we all get a group hug and a big pat on the back ..... well done peoples
    Regular Member Exclusive BV's Avatar
    West Midlands
    do they mean this site or us?
    http://www.vvoc.com/
    it says vectra c owners club not vauxhall vectras owners club
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Don't waste your money mate as the water pump on the Y30DT is driven by the aux belt, not cam belt
    Agreed, when changing the cambelt on the Y30DT does not require a waterpump
    Equally, you can quite happily leave the service interval to 100K miles
    However, the auxiliary belt is 80K miles
    Make sure this is carried out, plus ask for the waterpump main bearing to be inspected / checked
    Finally, on the cambelt change ask what they will be doing
    If it is a dealership and they say "just cambelt" then ask them to check TIS and correct
    If they don't mention valve clearances, go elsewhere
    If it is a garage then they may not be aware, so advise them the valve clearances MUST also be done
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The OP said it was copied from a thread regarding the 1.9cdti
    Quote Originally Posted by Celes View Post
    will be getting both aux belt and timing belt done in next 3 weeks as on 91000 now
    believe me wont be going anywhere near a dealership for it
    ill get the water pump checked but will only change it if bearings are worn
    it was john but i was searching for water pump on the y30dt
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    These days no one will even bother removing the rocker covers, let alone check the clearances of each valve.
    It's too expensive and it's not really a MUST. My mate spoke to a Y30DT specialist in Germany and he said and I quote: "Your friend must be crazy for even considering checking and adjusting the valve clearances! Don't repair if it's good." You can't beat the german logic...
    Quote Originally Posted by marktaylor View Post
    Almost the same mileage I had mine done at
    With the ECO Flex servicing it missed the 80K miles for the auxiliary belt, so both were done at the same time (makes more sense to me)
    Discussed before, but that is what the job on TIS quotes for
    VX paid for it on my cambelt change (quoted at 6 hours)
    Dealership thought "That was easy", almost me giving me the car back after just two hours, until I pointed to the worksheet, then realised the worksheet had "Check valve clearances" on it, which took the rest of the day
    Schedule G still quotes this on Part 11 for the Y30DT engine
  1. Good site
    By steve in forum General Chat
    Last Post: 7th March 2008, 10:01
  2. Good Cheesy Old Shows
    By VauxVeteran in forum General Chat
    Last Post: 20th December 2007, 00:46
  3. Looks like a good site...
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2007, 15:17
  4. How good is this site
    By mad4stela in forum General Chat
    Last Post: 27th May 2007, 21:10
