Motor has developed a fault in the cooling system basically the twin fans are coming on at full speed there have been no warning lights come up until Sat when engine light came on
i had it in the garage to fix on Thurs and they changed one of the sensors and it stopped till i got home and started again they said they could not get it plugged in till weds to find out the real fault ...they had changed the sensor on the belief that the problem was with that and the fault codes i gave them pointed to that (bull ++++) i know
anyhow today the fan has been going off and on if its on when i start the engine it stays on and same if it off ...what i have noticed is when the fan is on the temp gauge on the dash does not register if the fan is off it sits normal ...tonight i went to the shops fan is off and i have noticed engine light has also gone off ...i dont know what to do now ..i know there is a problem somewhere but im not going to pay the guys a fortune by replacing all the sensors and probably Fan Module as i know these come in at £120
anyone had anything like this or knows what is wrong below is the codes i got off the dash
P0691 Fan 1 Ctrl Circ Low
P0115 Eng Coolant Temp Sens Circ Interm Hi Volts
P0118 Eng Coolant Temp Sig Out-Of-Range Hi
