I'm going be getting some of these from hids-direct
Just want to make sure that if I get the H7's then they will fit the dipped beam for my 07 plate vec won't they?
http://www.hids-direct.co.uk/mtec-xe...lbs-p-481.html
You realise that they are nearly double the wattage of your current lamps don't you? The fuses will be too small and i'd also question the cable sizing for that amount of current.
yeah i was thinking the would be pretty powerful
would i be better going for the 55w version of the same bulb?
bump
I bought them,... and removed them straight away - rubbish.
You can have mine if you like? Don't waste your money.
Stick to a set of HIDs dude. The current will probably melt the wiring if the heat from the bulbs doesn't do damage to the inside of the headlight first. Would be worth saving for the HIDs.
ok thanks for the advice guys
I would not bother, you will be disappointed!!
Simmo i was looking at these ones this morning then read the info and found the following
"Please note: 100w bulbs are sold for 'off road' & 'Show Purposes' only"
So ordered a set of these of the bay.
HTH
nightbreakers do make a big difference to the standard bulbs, i had them but am now after hids. not sure what 'k' to go for though
