Results 1 to 10 of 11
Thread: These should fit....shouldn't they??
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    Talking These should fit....shouldn't they??
    I'm going be getting some of these from hids-direct
    Just want to make sure that if I get the H7's then they will fit the dipped beam for my 07 plate vec won't they?
    http://www.hids-direct.co.uk/mtec-xe...lbs-p-481.html
    Full Member Big Sig's Avatar
    You realise that they are nearly double the wattage of your current lamps don't you? The fuses will be too small and i'd also question the cable sizing for that amount of current.
    Jul 2010
    yeah i was thinking the would be pretty powerful
    would i be better going for the 55w version of the same bulb?
    Jul 2010
    bump
    Sep 2010
    I bought them,... and removed them straight away - rubbish.
    You can have mine if you like? Don't waste your money.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Stick to a set of HIDs dude. The current will probably melt the wiring if the heat from the bulbs doesn't do damage to the inside of the headlight first. Would be worth saving for the HIDs.
    Jul 2010
    ok thanks for the advice guys
    Woodbridge
    I would not bother, you will be disappointed!!
    Regular Member Baz07's Avatar
    Lancashire
    Simmo i was looking at these ones this morning then read the info and found the following
    "Please note: 100w bulbs are sold for 'off road' & 'Show Purposes' only"
    So ordered a set of these of the bay.
    HTH
    Regular Member madman's Avatar
    nottm
    nightbreakers do make a big difference to the standard bulbs, i had them but am now after hids. not sure what 'k' to go for though
