Thread: Adding Aux
    Woodbridge
    Default Adding Aux
    Can an Iphone be added to a standard head unit, through a lead?
    Also what is the power rating of the standard head units? I am not to sure what unit i have lol. It is not the same as the CDR2005. It is the standard one in the GSI with a tape deck and 4 disc changer. Anyone know the model?
    Mileage : 000
    I have the one with the tape deck and 4cd changer. It is a CCR2006.
    I also belive someone has done a bit of a "how to" regarding which are the correct terminals to conect to for adding an aux" socket. But I can not remember who it was.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Thats only for the 2005 Ed.
    Mileage : 000
    I was not sure which one it was. Cheers for that.
    Woodbridge
    Cheers Ed, your right, it is the CCR2006, just had a look it's written on the front lol.
    Mileage : 000
    Quote Originally Posted by Ginge7289 View Post
    I wonderd why you had not noticed the "name" on the front......
    Feb 2011
    Selby
    I have a CCR2006 in mine - I just use an adapter in the tape deck when I want to plug in my iPhone, and put the phone in the little pocket under the heater controls, with the wire running down the passenger side.
    You have five realistic options:
    1 Use a cassette adapter. Cheap (£5), good enough quality and removable. But does mean you can't use the tape deck without taking it out, and the wire might get in your way.
    2 Use an FM modulator. Either inline with the aerial lead or a transmitting type. Not as cheap as the tape adapter, but does mean you can use the tape deck without ejecting the adapter, and gives you more flexibility in where you put the phone (seen some nice installs in the cupholder or armrest)
    3 Wire a plug onto the auxiliary input used by the optional Trafficmaster or mobile phone interface. Downside is that it's only mono, and bandlimited (as it's designed to produce clear speech, not music).
    4 Solder an input directly onto the circuit board of the amplifier, with a switch maybe. Most risky, but if you've got the electronics knowledge is the most elegant solution.
    5 Buy a new head unit.
    Vehicle : SRi
    Mileage : 137000
    You can take the front of the 2006 hu off and run the tape wire inside and out the back, this way you have no wires on show.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Rated Power = 20 watts/channel
  1. Help adding photos on here
    By Telboy in forum General Chat
    Last Post: 10th April 2011, 11:48
  2. ncdc2013 adding a sub and amp
    By paulvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 01:44
  3. adding a turbo kit to 1.8 sxi
    By wilsons 1.8sxi in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 10:41
  4. Adding DAB
    By Blue Thunder in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2008, 21:57
  5. Adding Sub and Amp
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2006, 00:34
