Thread: Water, Coolant & Heater Problem
    Mar 2011
    Inverness
    Default Water, Coolant & Heater Problem
    Hi Everyone,
    Am new here after buying my SRI SAT NAV Vectra about 6 months ago , a few weeks ago started with an intermittant problem where the blower would blow normally then next day blow but not as fierce as normal, then back and to and so on and so on. Then started to notice that was loosing coolant , now have noticed that the passanger side foot well is soaking
    help anyone ?
    Full Member Big Sig's Avatar
    Could be a cracked heater matrix. Does it smell like coolant in the floor? Another possibility is the drain under the pollen filter in the scuttle panel is blocked and rain water is getting through the fan and into the passenger footwell.
    Mar 2011
    Inverness
    Hi,
    doesnt smell like coolant no, but to be ohnest have been topping coolant tank up with water at min as am going through it that fast
    where and how do i check filter ?
    Thanks again
    Simples - http://www.vectra-c.com/forum/showthread.php?t=108462
    or use the search button/how 2 section. (can you see that section not being a full member?
    Mar 2011
    Inverness
    thanks !
    Just stuck my finger in drainge that was totally blocked .. will try and remover filter and replace and c how we get on ....
    thanks again, hopefully it was as simple as that ..... here is hoping !!!! :-)
    Regular Member Innes's Avatar
    Plymouth
    Glad you sorted the flooded footwell. As for the coolant loss It could be that the coolant tanks has split on the seam. Carefully fill up the expansion tank then check the seam and see if there is coolant around it. This happend to mine. I bought a new one from the dealers for £18. Going to fit it this weekend.
  1. Water for coolant?
    By goafer in forum Engine & Drivetrain
    Last Post: 22nd December 2010, 23:02
  2. engine coolant/temp gauge/heater
    By redmoog in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2010, 21:27
  3. water coolant temp sensor....
    By bertiecbx550 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 13:54
  4. Coolant Leak, Water Pump?
    By rsocon in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 21:46
  5. Water Pump/Coolant
    By barkzz in forum Engine & Drivetrain
    Last Post: 22nd September 2008, 22:31
