Thread: 1.9 cdti power loss and fault codes
    Aug 2009
    Cheshire
    Exclamation 1.9 cdti power loss and fault codes
    Hi Folks,
    I sold my Vectra a good few months ago now but I am now experiencing some problems with the wifes Zafira 1.9 cdti (08).
    The engine managment light came on today followed bycatastrophic loss of power, no accelaration and max 50mph.
    The car has 32k on the clock and had been serviced regularly, (last serviced in January)
    I have been looking at the threads and I suspect it may be the EGR valve followed by 'limp home mode'.
    has anyone any advice on how to read the engine fault codes or reset them?
    also can anyone adivse me on other causes of power loss....the dealer has fairly scared the bjesus out of me with possible causes and I have read horror stories of £4000 repair bills.
    any advice would be appreciated !
    ps. I am just rolling up my sleeves to have a go at stripping the egr...will disconnecting the battery reset the warniing light?
    Cheers Jamie
    Regular Member AndyFoz83's Avatar
    Jan 2010
    Wolves
    have a look at this mate could be any of these probs
    http://www.vectra-c.com/forum/showthread.php?t=130008
    Mar 2011
    Bedworth
    Vehicle : Vauxhall Signum
    Trim : Elegance
    Engine : 1.9 CDTi 120PS
    Year : 06
    Mileage : 115000
    Hi Jamie,
    I don't know how closely related to your issue this is, but I've just fixed an EGR problem on my 2006 Vectra 1.9 CDTi 120.
    Whilst I've not experienced the engine management lights and 'limp home' mode, the car did have trouble on acceleration. Quite often as the engine speed approached 2,000rpm under gentle acceleration the car would jerk like crazy, as if I was tapping my foot on the accelerator.
    The first thing I did was disconnect the EGR wiring plug, and try driving the car. This got rid of the jerking problem completely, but caused the spanner and engine lights to come on.
    Using an app on my Android phone called Torque, and a Bluetooth OBD-II adapter, I cleared the ECU fault codes (basically telling me the valve was unplugged).
    The next thing I tried was removing the EGR valve and cleaning it with solvent and WD-40 etc. The valve wasn't particularly dirty - some of the surfaces were covered in a thin layer of black stuff. The mechanism was free to move as well. I cleaned it anyway, and as I guessed this had no effect on the jerking problem.
    Following unsuccessful cleaning, last week I ordered an aluminium oval blanking plate from eBay and drilled an 8mm hole in the centre. I then fitted this on the inlet to the EGR valve. My car has been running just fine ever since [touch wood].
    Chris
    Aug 2009
    Cheshire
    Thanks Gents,
    although the engine bay is a little more cramped, it look the same...I dont have an android phone though !
    Is there some simple way of reading/ resetting the codes? available by ebay or anything like that?
    Mar 2011
    Bedworth
    Trim : Elegance
    Year : 06
    Mileage : 115000
    I have just had a quick search on eBay and found this:
    LATEST UNIVERSAL FAULT CODE READER - U480 OBD2 UK
    If I was going to purchase a stand-alone fault code reader, I would probably go for that. However, I would definitely email the seller first to check about compatibility!
    Jan 2010
    Wolves
    i bought this one its never let me down
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=200562321099
    Aug 2009
    Cheshire
    Good News....it WAS the EGR valve, now stripped cleaned, polished, greased and reinstalled. worked a treat...now all I need to do is turn that damn engine light off !
    Thanks everyone. salute.
    Aug 2009
    Cheshire
    Exclamation EGR woes returned
    HI Folks,
    unfortunately the EGR valve has played up again this week, both times the car has gone into 'limp home mode' which as I discovered is ridiculously dangerous when you are in the outside lane of the motorway !
    I had a closer look at the Valve following the strip down/clean and lubricating and I found water dripping out of the 3mm hole which I drilled in the top...this makes me wonder wether the modification should include pluggin the end up again??? comments?
    anyways to avoid any further dangerous incidents I have ordered a new valve from the local dealer (£120 including gaskets)
    two things I have learned from this saga....the engine light eventually goes out on its own so no need to buy tool to reset it...just keep driving...
    ...and secondly the 'limp home mode' also cancels after a few miles, I set off from Birmingham and 30 miles later the engine came back to life...up to that point I was crawling along in the inside lane at 60mph.
    I have to say though this is getting very much like the niggles I had with the Vectra...big 'tut tut' to Mr Vauxhall
    Regular Member sloper's Avatar
    Oct 2010
    bradford
    Get the EGR mapped out and you will never suffer this issue again
  1. Please help! Serious loss of power, EGR fault code
    By dirtydan in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2012, 11:25
  2. Replies: 0
    Last Post: 26th August 2012, 03:15
  3. Loss Of Power On 3.0 cdti sri - please help
    By L.Hamilton in forum Engine & Drivetrain
    Last Post: 14th June 2011, 18:00
  4. Fault Codes V6 CDTI
    By r.bailey63 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 00:11
  5. Fault codes on 1.9 120 cdti
    By Keith Jones in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2009, 19:52
