Thread: Getting inside a Dual Climate Control Panel
    Devon
    Default Getting inside a Dual Climate Control Panel
    Hi guys!
    I need some advice on how to take the Dual Climate Control Panel apart please!
    I know how to remove the actual unit from the dash but I need to get inside the actual unit as the main temperature control push button is not working too well, making it difficult to select the different options (air distribution, Eco mode etc). I want to get inside it to see if I can fix it.
    Anybody know how these come apart?
    Full Member Big Sig's Avatar
    Its actually quite easy. I stripped mine as the old one stopped working and when the new one turned up the outer was damaged so i had to swap them over. IIRC they are just clipped together from the rear. The knobs etc stay where they are and it all comes out the back.
    Devon
    Sounds easy - thanks. I know complete new units need to be Tech 2'd in, so if I can't repair mine could I just swap the front over (keeping the other bits, PCB etc from mine) from the new one without Tech2?
    No, when it comes apart ALL of the electronics come out of the housing. I had to have mine tech 2'd into the car - but only because the new one didn't have the air quality option enabled. Apart from that one missing option it worked fine. However, the one I replaced on my signum didn't work at all until tech2 got involved. You maybe lucky and it might work.
    Devon
    Thanks! I'm hoping that If I just swap the fronts over and I'll be keeping all the electronics from my exisiting unit, it will still think it's the original unit fitted so no Tech 2 required!
    But now you've got me thinking.
    I don't have the air quality option in mine at the moment (or residual heating). I know there are various part numbers available for the Dual Climate panels so if I do buy another control panel, can I buy a different one (with these options) and have it activated with options such as air quailty and residual heating using Tech 2, or do I have to stick with the current part number only (13138916)?
    The residual cooling/heating works by pressing the auto button with the ignition on in the first position, is that what your doing?
    Mine in my GSi were very similar numbers but it did have some options missing. I guess they could simply be activated with tech2 for yours. But in 5 tears of signum/vectra ownership I NEVER used the residual function other than to test it worked!
    Devon
    Sorry I didn't mean residual heating - I know that's standard on all Dual Climate control versions and it does work on mine! It's the automatic air quality mine doesn't have and I think it's called the auxillary heating?? but I'm not sure. So, just to check you did put a (slightly) different part number into your GSI and it still worked?
    Quote Originally Posted by dae36 View Post
    Yes it was very slightly different but i did check with vx that it would work as there are lots of different types of the same unit although i have no idea how they differ as they all look the same!
    Sorry, I didn't know you meant the aux heating. not sure how that system works.
    Sep 2012
    facinas
    did you ever get the fan knob working. mine is bad
  1. dual climate control issues
    By gsisi76 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 19:15
  2. Dual zone climate control
    By mikeeaston in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 19:53
  3. If I fit the climate control panel....
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2012, 12:51
  4. Dual Climate Control
    By dae36 in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2011, 16:54
vectra c climate control panel repair
vectra c sticking climate control button
