Results 1 to 3 of 3
Thread: Tapping noises, inection deviation, and oils
    Full Member Teapot's Avatar
    woodbridge, suffolk
    86 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Default Tapping noises, inection deviation, and oils
    A couple of weeks ago I posted regarding a tapping noise from the signum's engine which I suspected may be caused by a dicky injector.
    To recap, there is a loudish tapping noise when the engine is cold, which gradually decreases as the engine warms up. It is worst during accelleration, and least on the overrun.
    It is a 1.9cdti 16v of 2004 vintage, with nearly 120k on the clock. The noise has gradually worsened over the past year.
    I finally got around to putting it on the opcom and checking the injection quantity deviation. The results were as follows (measured with a partially-warmed engine at idle):
    Cyl 1: -0.25 mg/stroke
    Cyl 2: 0.24 mg/stroke
    Cyl 3: 0.53 mg/stroke
    Cyl 4: -0.52 mg/stroke
    From reading other posts on these forums, these would appear to be normal. Is that assumption correct? Is it therefore safe to rule out the injectors as the cause of the noise, or can they fail in other ways that cause noise but not show excessive deviation?
    My mate was outside the car when I started it at the weekend and noticed that the tapping was very loud for the first couple of seconds after starting. He suggested that something (possibly a small end bearing or valve lifter) was noisy until the oil pressure had built up, and that it was unlikely to be diesel knock, therefore eliminating the injectors.
    He suggested that given the inevitable mechanical wear resulting from the mileage, it would be beneficial to use a higher viscosity oil. However, I pointed out that due to the DPF, it must have an oil meeting GM spec LL-A-025 or LL-B-025. All the oils that I can find which meet this spec are 0w30 or 5w30, which seems to rule out that option.
    Since I bought it two years ago, I've been using the GM synth dexos2 oil and changing it and the filter every 7-8k miles.
    Anyone have any thoughts on these issues?
    May 2006
    scotland
    Hydraulic valve lifters maybe. An engine flush helped in the past when I had this in a Rover.
    woodbridge, suffolk
    86 Post(s)
    Trim : Design+
    Mileage : 101000
    Thanks for that - I ruled out these engine-flush things as 'snake oil' a few years ago, but if you can recommend one that worked in your experience then I'll give it a try.
    Does anyone else have any thoughts regarding my problem?
    thanx
  1. vectra 3.0 sri cdti: 75 % power loss. No inection
    By mtqn in forum Engine & Drivetrain
    Last Post: 27th June 2012, 23:47
  2. Injector Deviation
    By pthres in forum Engine & Drivetrain
    Last Post: 30th April 2012, 19:12
  3. tapping and ticking noises ?
    By djlee in forum Engine & Drivetrain
    Last Post: 17th March 2012, 13:17
  4. Replies: 7
    Last Post: 22nd August 2011, 14:41
  5. Gulf Oils now available at Opie Oils
    By oilman in forum The 'Off Topic' room
    Last Post: 21st May 2009, 16:09
vectra c injection quantity deviation
