Results 1 to 10 of 15
Thread: V6 CDTI Induction kit?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default V6 CDTI Induction kit?
    Is there an induction kit available for the V6 CDTI?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Bump
    I would have thought so. What sort are you after? Open or closed filter?
    Just had a quick look on ebay, something like THIS would probably fit and for a tenner its ideal to see if you like it before spending maybe £100 on one only to find you don't like it.
    I had one of those on my GSi and it worked as well as a K&N over priced kit. Some moan on about heat soak but to be honest I never noticed any and the sound more than made up for it.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Open... i think. I was thinking of ducting the air from the front up towards the new filter. Another problem is, what to do with the computermabob that sits on top when the airbox is removed?
    Feb 2011
    barnsley
    I just went for a K&N panel filter for my V6 CDTi. Cost about £40 from Ebay.
    Open induction kits do suffer quite a bit from heat soak. I tested this years ago on my mk2 CRX VTEC.
    I'd gone quite crazy with the tuning, cams, pistons, ported head, flywheel, bigger injectors, inlet manifold. DTA ECU the works so wanted the best possible air intake system!!
    I could plug my laptop into the DTA ECU & watch all the info from the various sensors in realtime as i was driving.
    I'd started off with a huge K&N cone & a carbon intake pipe. I can't remember what the exact figures where but during the summer the engine bay temp stayed quite high up to about 50+mph. At the time it had 2x 3" cold air feeds & 1x 2" cold air feed. So with no cold air feeds at all the engine bay prob wouldn't have cooled down as much at 50mph
    I then had a carbon airbox made to fully enclose the K&N cone & had it fabricated to use the 3 existing air feeds. The engine bay itself around the airbox was slightly warmer as the cold air was being channeled into the airbox & not just into the bay.
    I then put the temp sensor inside the airbox & the temp was a hell of a lot lower at all speeds.
    In the end the CRX was running 236bhp at about 7.5k rpm. Not bad for a NA 1.6!! well, the had was the orignal 1.6 but the block was from a 1.8VTEC Civic & had oversized Type R pistons fitted!!
    Quote Originally Posted by BigWilko View Post
    Very good question, I'd forgotten about that. There is probably room to cable tie it securely but i cannot remember.
    For £10 those ebay ones are great. As for the heat soak, 500bhp cossies, can they all be wrong?? Loads of tuned cars use them and they are too cheap to ignore. Even if you do worry about the heat.
    As i said before, i've used open ones on many cars and never noticed any bad effects from the heat. Even if its 5hp, so what
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Yeah, for a tenner, might give it a go. I've seen on the MX5's they sometimes use one of the fog light holes for the air intake, not entirely sure about that on the Siggy. I also thought of putting a pair of astra GTE style vents in ( http://www.tuning.gen.tr/imagdatas/1867_a.jpg) Not bothered at the mo about big exhausts and mega bhp. I used the 10k boost a little while ago and the sound without the air box connected was sweet. I'd just like to hear a little more of the V6 tone... and a few little extra BHP's is always nice.
    There is plenty of places to run hoses for cold air feeds if you wanted too.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If you do get this one please post a vid of the sound. Would love to hear it before I go down the same route
  1. 1.9 CDTi wastegate chatter???? Induction kit....
    By Vectra Adz in forum Diesel Engine related
    Last Post: 7th July 2012, 12:27
  2. CDTI induction kit anyone got one?
    By ONEMINUTESILENCE in forum Diesel Engine related
    Last Post: 2nd August 2011, 21:10
  3. 3.0 cdti Induction Kit?
    By redleader in forum Diesel Engine related
    Last Post: 14th January 2010, 00:44
  4. Simota Induction Kit 1.9 CDTI
    By MattW in forum Parts for sale
    Last Post: 9th March 2009, 21:19
  5. CDTI induction kit
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2007, 21:37
