Thread: Clunk from driver side front wheel?
    Regular Member rosssri's Avatar
    S.Lanarkshire
    Default Clunk from driver side front wheel?
    My 09 plate vectra sri has developed a clunk over the last 2 weeks. At first I thought it was maybe the tyre catching the recently moved mudflaps as it sounds like the noise that happens when you tap the plastic lining inside the wheel arch. It's not this after I stopped the car as soon as it happened this morning to check.
    It only happens when turning to the right slowly it doesn't happen at speed & it doesnt do i regularly. It was loud enough for a work mate who was standing in car park at work to hear it when I turned into the car park last week.
    Does anyone have any ideas as to what it could be maybe strut mount bearing or even a cv joint?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds like a snapped spring fella
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Regular Member cockney16v's Avatar
    stoke on trent
    just had the same noise on mine turned out to be the nut had come loose on the drop bar link
    S.Lanarkshire
    I've booked car into dealers on Saturday morning to get it checked out. Hopefully if they find anything it'll be replaced under warranty as the cars not 3 years old yet.
    S.Lanarkshire
    Does anyone know if a broken spring or whatever it is thats causing this will be replaced under warranty on the car? It's an 09 plate.
    Regular Member Craig1985's Avatar
    harwich essex
    Yes if the cars under 3 years old and under 60k
  1. Front trim driver side for SRI CDTI estate/Help!
    By padams9839 in forum Bodywork & Interior
    Last Post: 8th March 2011, 22:28
  2. Driver side wheel no good in the snow!!
    By goodsparkle in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 22:20
  3. Front driver side rattle
    By bizerk in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2009, 15:37
  4. Front driver side spring noise
    By barracuda in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2008, 11:23
