Results 1 to 10 of 11
Thread: TC or ESP
    Sunny UK
    Default TC or ESP
    Hi
    I have a 04 v6 cdti sri...in the owners manual it describes both traction control and electronic stability program obviously using the same switch depending on what your car has.How do i know which system i have?
    Ta
    Johny
    Hertfordshire
    I believe all the V6's have ESP as standard.
    Also, if you have a FACTORY FITTED TC/ESP switch on the dash, then you have ESP not just TC.
    Melbourne, Australia
    Quote Originally Posted by Johnytuono
    Hi
    Ta
    Johny
    Not all V6's have ESP (at least in Australia anyway).
    Check the ABS unit under the bonnet. The units with ESP are made by TRW and should have ESP written on them somewhere.
    SOMERSET
    In my Vectra 2003 models brochure, ESP was only available on the GSI ONLY and not anything else. In 3 years of owning my car it has only worked twice when i drove hard into a wet corner and the back slightly came around, then ESP kicked in (love it) thank god.
    Regular Member solorider's Avatar
    swindon
    all european v6 models have esp
    Feb 2006
    shrewsbury
    I have V6 Signum. I have no button to turn any such driving aid on or off.
    i do..
    don't know about our sigbum thou...
    Regular Member ANDY GSI's Avatar
    dumbarton,scotland
    me 2
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I don't know about earlier years, but ESP+ is up here standard on Opels (at least Benelux, Germany...).
    On top off that, V6-engines have standard IDS+ (and that is not the same!).
    I don't think the button is still available, and if he is, I think I've read somewhere that even when it's off, if the ESP thinks it is needed it turns itself on automaticly.
    But, why would you want turn ESP off? (Except in winter in snow on a hill, perhaps... don't know yet)
    (it is the same on a BMW with the DSC/DST-switch which works only at low speeds)
    Sweden
    Quote Originally Posted by sig63
    The same here in Sweden !!
