Results 1 to 10 of 19
Thread: EGR replaced. Now the car is running worse
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Default EGR replaced. Now the car is running worse
    Yesterday I replaced the EGR with a new one, but after I got the car on the road, it behaves much worse than it did with the modded EGR I had (removed the pin that pushed the valve).
    Although I had the EML light ON all the time, the car was running great.
    Now the EML is off, new EGR fitted, but when I drive it, around constant 1700-1900 rpm I get some really bad jerks and a strange noise comes out, I think from the turbo.
    If I accelerate, the car goes like it should. But if I stick to 1800 rpm I have these jerks and noises (something like ch-ch-ch on every jerking).
    I would like to put back the old (and better) EGR to see if I still have the jerking.
    Anyone know what could be the problem?
    Engine : 1.9 CDTi
    Why did you remove the pin from the egr?
    Isnt that what you need to regulate the gas flow?
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Old EGR wasn't working as it should, so I tried this solution on my own. Apart from EML light which was always ON since, the car was running much better.
    I wanted to see if it works better with a new EGR I had lying around for 6-7 months. Well... it doesn't run better, that's for sure, but I can't figure out what's wrong. I don't think it's the new EGR's fault, because it's brand new.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    When you replace the EGR valve you are supposed to have an engine update. Sounds like the one you have fitted is jamming open.
    Gazza4
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Are you referring to the ECU's software? You saying it need updating?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Lao View Post
    Yip. Simply replacing the valve may not correct the problems. Also ontop of it does the valve actually move freely?
    Gazza4
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    I'll check it tomorrow. I put too much confidence in it being new.
    Feb 2011
    derby
    Im having the exact same problem at the minute as well, the symptoms are the same and its now worse after i replaced the egr. So if you find the cure let us know how you get on.
    CHESHIRE
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    arite gazza4 , those this apply if your running the latest software update , reason i ask thinking of getting a new egr valve off ebay .
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by dave r View Post
    Technically when you replace a component in an engine these days you should 'let' the ECU know the component has been changed. You may get away with a software update and repalcing the valve later but I'm not 100%.
    Gazza4
  1. Z18XER Burnt valves replaced/ still not running right
    By aeu9921 in forum Engine & Drivetrain
    Last Post: 5th February 2013, 22:08
  2. Worse job ever ?.......
    By martyngell in forum Y & Z30DT Specific
    Last Post: 2nd August 2012, 19:55
  3. White smoke getting worse and worse
    By alphabravo in forum Vectra C / Signum Troubleshooting
    Last Post: 19th March 2011, 01:04
  4. Its getting worse..........
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2009, 18:23
  5. Bad to worse!!!!!!!
    By Caterman in forum General Chat
    Last Post: 25th December 2007, 06:52
new egr valve car worse
