Thread: best way to remove silicone
    Liverpool
    Default best way to remove silicone
    i have my eyebrows siliconed on, i am going to remove them to have them painted but obviously i am going to have to get rid of the excess silicone, any easy way of removing? or am i going to have to pick away for hours?
    Plus, would leaving the brows overnight in petrol harm them in anyway? just want to get all paint off like that rather than sanding
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    Screwfix do a Silicon Remover for about £10, then I'd use a Safety Razor blade. Just remember to take your time and tape one end of the blade up.
    Kings lynn
    you could use stanley blade to cut off slowly. then brake cleaner on rag to get excess silicone off afterwards.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I think it's vinegar that breaks down silicone. If it's not there is a relatively harmless chemical that does.
    Regular Member Keif's Avatar
    In the Garage
    Careful as the headlight lens is plastic.
    Some chemicals will damage the plastic. making a cheap job very expensive.
    Mar 2011
    Basically anything without Acetone in it (Nail Varnish remover etc....) This may perish the plastic, not to mention what it'd do to your headlight seals.......
    WGAF#5
    i used acetone on my headlights and it removed the silicone ... no damage was casued to the lights
    but make sure yoru sitting outside when you do it as the fumes are lethal
  1. silicone hoses
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2012, 15:01
  2. Silicone Hoses???
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2010, 20:35
  3. Silicone Hoses
    By bigboynigs in forum Petrol Engine related
    Last Post: 30th April 2010, 08:59
  4. Silicone hoses??????
    By jared.ryder in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2008, 09:11
