Results 1 to 10 of 17
Thread: Passenger Curtain Air bag problem
    Regular Member Winty's Avatar
    Feb 2011
    Surrey
    Question Passenger Curtain Air bag problem
    Hello
    I have a reoccurring fault with my Vectra-C 56 plate Passenger Curtain Air bag. Air bag warning light keeps coming on, fault is low voltage.
    Problem only occurs when it is sunny and the bodywork warms up, I can clear the fault at night after it has cooled down or first thing in the morning.
    When testing during the day and bodywork is hot/warm that fault is constantly present, when the body has cooled down fault disappears and can be cleared.
    I have had half the roof lining down and checked all along the air bag but I’m unable to locate the connector (am I being dumb or something )
    Really would like to get to the bottom of this issue as it is becoming a pain clearing the fault code every night.
    Please help
    Mar 2011
    kent
    The connector is towards the back, you have a trim in your boot area which is held by one or two torx srcews and then should pull off with a little persuasion. connector will have an orange clip which pulls up about 5mm then green part will pull out..BE CAREFUL these are quite delicate
    Feb 2011
    Surrey
    Quote Originally Posted by wbm156 View Post
    Which panel do you mean? Is it the one attached?
    Mar 2011
    kent
    sorry mate my mistake thought you had a signum... should be a panel by your back screen
    Feb 2011
    Surrey
    This one?
    Feb 2011
    Surrey
    Ok, have got the panel off, taken the connector off and put back on, now i get a Low Resistance fault, connection sitting at 0.5-0.8ohms
    Any ideas?
    Feb 2011
    Surrey
    B0023 - Passenger Curtain Airbag Squib Circuit Low Resistance
    (0E) - Present
    Feb 2011
    Surrey
    Am I looking at a new air bag? Any ideas?
    Mar 2011
    kent
    only thing i can suggest is when you took the connection off the bit that slides up to release the connector has a small tag at the bottom check this because when it is pushed down it breaks the circuit if you take a picture with it unconnected i should be able to tell you if it's ok as i had this problem
    Feb 2011
    Surrey
    Hello, sorry just got bak from Chessington ;o) see below, thanks.
  1. Wiper Electrical Problem? (Not sticking or cold weather problem)
  2. curtain airbag connector
    By alexiker in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2011, 12:49
  3. Vectra passenger sun visor retaining clip problem
    By Ollie in forum Bodywork & Interior
    Last Post: 19th January 2010, 16:29
  4. HELP please !! how do you replace os curtain and seat airbags
    By shauny d in forum Electrical & ICE (including SatNav)
    Last Post: 4th January 2010, 14:33
  5. Curtain airbags and mike cables
    By JuzzyD in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2007, 14:27
vectra c curtain airbag plug
