Thread: vec b heavy clutch
    Glasgow
    Default vec b heavy clutch
    hi guys any idea why the clutch would be heavy? also the biting point is pretty high, it doesnt need pushed to much to change gear and it feels like the gears jump out when i go to change..? 2.2 dti..
    Chelmsford
    Several things it could be, from the cheap and simple to the very expensive...
    Worn out slave cylinders aren't a rare occurence on the C... How many miles has your car done? High biting point is also a sign of normal wear and tear on the clutch plate.
    Something I found with the clutch on the C is that it has to be pushed fully to the floor to keep the hydralic system working properly. I've always felt mine travelled too far and the bottom inch or so didn't do anything, so I fitted my own stopper behind the clutch pedal. This worked for a while, but after a few days the gears started to grate as the clutch wasn't disengaging properly. Removed the stopper from the pedal, pushed and released the clutch a few times, all was fine... Very odd...
    Glasgow
    its a Vec B mate..
    Chelmsford
    Ah, oops!
    Try www.vvoc.co.uk!
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. Both of them (pic heavy)
    By m111kan in forum Quick Photo Album
    Last Post: 4th April 2010, 12:32
  4. Heavy clutch
    Last Post: 29th August 2009, 00:32
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
