Results 1 to 3 of 3
Thread: Door Warning Light
    st neots
    Default Door Warning Light
    Hello All,
    I am having a problem with the rear passenger door warning light staying on when the door is closed???
    I have checked the door and it is fully closed. I have used a screwdriver to close the lock when the door is open and the light is still on after two clicks of the lock, also the red kirb light is staying on? Also the interior light is staying on when the car is locked (but seems to go off after a while) and when driving so I have manually turned it off.
    I'm also getting a bit frustrated to say the least with the beeping everytime I pull away....
    Any help will be great
    Rich
    st neots
    Quick add,
    Could this be a simple wiring problem or is it a case of replacing the whole door lock?
    Rich
    Regular Member VECTRA HEAD's Avatar
    Derry
    its the sensor in the door lock,i had the same problem,just replace the door lock and its sorted,i think the part is approx £60 iirc
  1. driver,s door closed but dash light says door is open
    By wulza in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2012, 01:47
  2. Door open warning?
    By blues n twos in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2009, 20:28
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
  5. Door, light warning panel, Not the usual
    By 111 in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2007, 11:22
