Thread: Steering wheel still not looking straight after tracking
    Solihull
    Default Steering wheel still not looking straight after tracking
    Hi everyone
    had MOT done and few repairs with it including tie rod end, drop link, and another repair to do with steering. this knocked the tracking well out, as after repairs when i was driving perfectly straight, the steering wheel was turned left.
    i phoned the garage and they said i needed tracking done. went to plume tyres yesterday who did the laser wheel alignment (fronts) and now when i drive, the steering wheel is positioned much better when driving perfectly straight, but now only very slightly turned to the left.
    shall i bother getting in touch with plume tyres again to correct this? or is this normal?
    thanks
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Mine has done the same after four wheel alignment. it was fine the last three times it was done but now its not playing ball. They should have centered the steering when they done the alignment so it could mean your steering wheel needs to be moved slightly. I am going back next week to ask them and maybe re check it
    Solihull
    ok thanks for the reply
    will give them a ring 2mara. but i'm assuming the tracking is fine? its just to do with steering wheel alignment? will this have any impact on the car/tyres etc? if left uncorrected?
    thanks
    Full Member paul.sessions's Avatar
    leighton buzzard
    mines the same and i remember a few similar threads before seems like another common problem
    Sounds like they have just done a front wheel alignment, and not a full four wheel alignment
    If the steering wheel is not level, take it back
    The usual trick on obtaining the correct front wheel alignment is to concentrate on the toe only, typically one side only, which then results in the wheels pointing in the same direction, resulting in the steering wheel becoming offset; poor workmanship
    Solihull
    ok thanks
    i'll give them a ring 2mara
    Solihull
    Went back to original place, they did tracking again and it was out. They corrected it and now steering is perfect again :-)
  1. Steering wheel not straight, but car drives straight?
    By Danny.surname in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2013, 00:21
  2. Steering wheel not straight
    By BooDaChris in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2013, 23:24
  3. steering wheel to one side,while driving straight
    By RRadek in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd September 2011, 10:50
  4. Steering wheel points left when going straight
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2008, 21:27
  5. Tracking - steering wheel slightly out
    By S888 SRB in forum Suspension, Wheels & Brakes
    Last Post: 17th February 2008, 23:03
vectra c steering wheel moving
vectra c wheels tracking
car still not driving straight after tracking
how to straighten a steering wheel vectra
vectra tracking
vauxhall vectra c tracking
vectra steering wheel not straight
