Thread: Brake light fault:-possible cure?
    North Tyneside
    Smile Brake light fault:-possible cure?
    Hello there, I have a 1.8 petrol Design spec and recently experienced the dreaded "Brake light out " fault showing on the screen. It told me that the left hand brake light was out. I checked the bulbs and found nothing wrong the bulb was fine and functioning normally. Over the following 3-4 days the fault showed again about once a day, again nothing wrong. Eventually I got fed up with it and out of desperation switched the top bulb with the one below.All was well for a couple of days and then the fault re-appeared only this time with the right hand brake light. I left it for a couple of days and sure enough the fault kept appearing for the right hand brake light. I did the same again and swapped the bulbs. That was over 2 weeks ago and no fault has appeared since then and brake lights are working perfectly(so far). I'm obviously hoping it's a permanent cure. No idea if it will work on every Vectra but it may be worth a try for anybody with the same problem.
    Last edited by pilgrim; 27th March 2011 at 10:20. Reason: Error in desc ription of fault
    preston
    the bulbs appear ok but are on the way to a slow death.
    the reason the error shows is it senses voltage changes caused by the bulbs deterioration
    i've often found that once one bulb "goes" others soon follow, so i've taken to replacing 4 tail/ brake bulbs as a single operation to save messing about identifying which bulb is faulty.
    You could just clean the contacts too.
    North Tyneside
    Ref my original message re brake light bulb warning and my attempt at a cure which at the time worked. Just an update to say it's still working, I've had no more warnings since switching the bulbs and that was 3 months ago so it seems to have worked, all bulbs still ok.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by pilgrim View Post
    Probably was a dirty connection somewhere. Cured by removing and replacing the bulbs
  1. Estate Rear brake light fault?
    By dv8 in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 20:17
  2. Brake light fault indicator.
    By Ste89 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2012, 18:15
  3. brake light fault (confused)
    By frigosolver in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2012, 15:34
  4. Brake Light fault
    By interceptor-jamie in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2011, 21:05
  5. strange brake light fault
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2010, 14:55
