Thread: Vectra C SRI 2.2 dual rear exhaust - what is needed
    NIGHTCD
    Guest
    Default Vectra C SRI 2.2 dual rear exhaust - what is needed
    Hello.
    is there anyone that have mounted 2 exhaust rear silencer to their Vectra C 2.2 SRI (Z22SE) ?
    if yes, what rear silencer is fitted to the rear of the car ?
    and what parts is needed ?
    do i have to buy the center box to ?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Yup, all I did was buy a second hand 2.0T twin system. I cut the twins system before the Y, did the same to my system and then slid the 2.0T's system over mine and clamped it up, jobs a good un, cost me £60
    NIGHTCD
    Guest
    so in the principal i can use the middle section fron an 2.2 Direct ?
    did the y fit over the original middle section of an 2.2 non direct ? (was this y welded on ?)
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I dont know the size of the pipe on the direct, all I know is that its a different part number. Yes the turbo pipe is larger than the 2.2's so I just slotted it, slid it over and clamped it like a normal clamped zorst section. If I remember rightly, the y and the centre section is all one part, hence the reason I cut it.
    NIGHTCD
    Guest
    thanks
    Regular Member nidgeboy's Avatar
    Sep 2010
    Liverpool
    dont suppose you know the dimensions as i have the set up sat here waiting to go on and was gonna buy a sleeve but not sure what size to get
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Sorry mate no. If its a NET's system you have then you dont need a sleeve, just cut two notches in the end of the pipe so it can crimp, then pop on some exhaust putty and clamp it up.
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    I want to make my exhaust a twin, what am I best looking out for being a diesel.
  1. dual exhaust upgrade on a cdti,advice needed
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 09:56
vectra c 2.2 direct exhaust
vectra c 2.2 sri exhaust
vectras c 2.2sri s22se or s22yh
vectra c dual exhaust
https:www.vectra-c.comforumshowthread.php133526-Vectra-C-SRI-2-2-dual-rear-exhaust-what-is-needed
vectra c 2.2 sri exhaust silencer
signum exhaust is same as vectra c
vectra c sri exhaust
vectra c 2.2 sri double exhaust
dummy twin exhaust on vectra c
kn panel filter with exhurst system
exhaust for vectra. c sri
2.2vecta exhaust
price for vectra c sri exhaust. in leeds
vectra 2.2 dual exhaust
exhaust for 2004 vectra 2.2sri
2.2 vectra c exhaust same as 2.0t
Rear silencer vectra 2.2
