Thread: vec dti
    Jan 2010
    norfolk
    Default vec dti
    hi iv just bought a 03 plate vectra dti 2.o and i have a whooshing noise when accelerating and doesnt seem to have much poke also what is the actual mpg for this engine , it has done 122000 miles , the car is running ok just this whooshing sound , hope somebody can help thanks
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    er the noise will be the turbo spooling up mate and the dti are only 100hp so not massively powerfull in my old dti i was gettin 36-40 around town
    Jan 2010
    norfolk
    hi thanks , my old 52 plate never made that sound just a bit worrying as just bought 53 plate one .
    Check the boost hoses for splits also have a listen under the bonnet as someone revs the engine, if its not the turbo spooling you may have a boost leak on one of the hoses or a split in the intercooler.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    As Rapala said. Duff hoses are quite common on the DTi's. Get someone to hold the revs up enough to be onto the boost and have a listen around the engine bay.
    Regular Member madman's Avatar
    nottm
    i can get 50+ on a good steady run, and get at least 40 knocking around.
    Jan 2010
    norfolk
    Default vectra
    hi thanks for replies , i ve been looking at car and found the hose had split , just need to find cheap one somewhere , also would this count for excessive fuel consumption , and loss of power thanks
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    100hp is a bit dead, it was never changed from the Vectra B, so same power and much much heavier car to power. And a full tank gives me 530 miles on average.
    Jan 2010
    norfolk
    with reference to previus reply i dont get nowwhere near 40 around town OR ON A RUN ANY IDEAS
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by octoman View Post
    Yes mate can also make it go into limp home mode. I changed my small vac pipes for silocone ones from ebay its a cheap fix, depends on what pipe has split though.
