Thread: Knocking from the front
    Sodding Typical on Sea
    Default Knocking from the front
    Car had a DMF clutch and slave all fitted when I bought it at 34.5K but noticed a slight but annoying little clunk off the n/s on really rough sections of road. From my 9-5 I know the things to check and the suspension is all within tolerance and have mostly ruled this out.
    What I have noticed is that the engine seems rather more loose than I would like to the point that it has a slight clunk all it's own when you start it. Are the engine and gearbox mounts prone to softness /looseness / failure, if so which one is the more likely to be a suspect and can anyone paste an epc diagram of the mountings to let me see what I am up against.
    I sort of suspect one of the gearbox mounts as the car had the cradle supporting the engine during the DMF transplant and the o/s engine mount was left un-touched,,,,,,
    What sort of speed are you doing when you hear it?
    My car had been doing this for a LONG time, nothing found
    In December it was reported the nearside front drop link had play
    Replaced both front drop links two weeks ago and the noise has gone
    walking pace over rough pockmarked roads for one, but, why I suspect the engine mount is that when I engage the starter when the engine catches I get a thunk! as the engine jumps into life, or am I being a bit over hopeful at being a simple fix for once
    Also, Doesn't do it over speed humps only sharp drop hit's
    Who did the DMF?
    Did they replace the clutch at the same time?
    Not pointing any elbows, but the clunk on gearchange...
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    I have same issue mate start and it clunks to life same when I shutdown and it shakes I def think it's engine mounts but there are 3 one each side and one in the bottom under the tray engine to gearbox
    No idea how much these are mate but let me know if you find a price for them
    Who did the DMF?
    Evans Halshaw did DMF clutch and slave I don't get any on gearchange only on starter motor after the engine catches.
    Steven I do think its one or both of the gearbox ones but will do one at a time then do the upper engine side as I do know the suspension and it is all fine and tight enough to discount that.
    thanks guys confirming my suspicions nicely.
    preston
    i'd suspect mounts too
    but i had the same on the rear, eventually turned out to be arb bushes....so don't count this out
    for the cost of them, i'd replace front and rear arb anyway. rears are easy, fronts, might need to drop subframe to access the bolts
  1. Knocking at Front......... Help
    By johnny1983 in forum Suspension, Wheels & Brakes
    Last Post: 5th February 2012, 17:46
  2. Knocking from front
    By RBH in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2011, 18:51
  3. knocking from front end
    By danny_n in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 14:40
  4. knocking front end
    By VECTRA HEAD in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2009, 20:24
  5. Knocking Front O/S
    By Ralph wiggum in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2006, 19:40
