Thread: soft brakes
    Glasgow
    Default soft brakes
    Hi guys I picked up my b dti today but the brakes have a lot of travel but they have apparently been bled as it is new brakes and stuff. Any suggestions?
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Quote Originally Posted by twaiter View Post
    "Apparently" bled? Or 100% guarentee'd Bled?
    Bleed them again, if that fails. New brake fluid and top it right up. Otherwise it may be a pedal issue. Which is very, very rare.
    Glasgow
    Not 100 percent sure but the garage said they done it. Personally I don't think it was as when I test drove it it was the same feeling but when he put it thru the mot I requested it failed for this issue but then passed a few days later? So how would I bleed the system my self?
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    The 'b's suffer from air trapped in the ABS modulator, to thoroughly bleed them out you need Vauxcom or such to activate the ABS modulator whilst also bleeding the brakes.. (as per TIS instructions)
    Glasgow
    i have a tech 2 thing on the laptop, so how would i go about bleeing the brakes? is it just a case of taking the cap off the brake fluid canister and pushing the breaks?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Nope, there a bleed nipples on the calipers.
    Gazza4
    Barnsley
    could be normal mate mine has being like it since new , had new discs pads fluid bleeded up everything still not brilliant
    Glasgow
    it just feels dangerous! im scared of when i have to break hard!
    i read that the clutch uses the same fluid and i thought as my clutch was heavy it might be related?
    i wonder if its the brake lines are gubbed? maybe expanding under braking pressure and not applying the force... but then surely that alone would fail an mot..
    I've jsut come from a Signum with 345mm VXR brakes and the Vec B's aren't the best but I'm just going to try and be more careful - we'll see if the MoT test brings up any issues with them...
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    them ABS modulators do go faulty and cause soft pedal...
  1. clutch has gone very soft
    By carl bear in forum Engine & Drivetrain
    Last Post: 13th September 2012, 15:48
  2. soft suspension.
    By jimmyred in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2011, 16:47
  3. very soft brakes
    By dodus in forum Suspension, Wheels & Brakes
    Last Post: 19th July 2009, 19:55
  4. Are cops too soft.
    By Gr4eme in forum The 'Off Topic' room
    Last Post: 5th March 2008, 15:05
  5. Am i getting soft in old age?
    By Devil Nev in forum General Chat
    Last Post: 29th December 2006, 21:21
