Thread: Vibrations?
    Regular Member Exclusive BV's Avatar
    West Midlands
    Default Vibrations?
    Been having quite a bad vibration for some time now. Had the wheels balanced 3 times (different garages) with no improvment. Swapped the wheels front to back earlier and made a big difference but there is still a slight something there.
    Checked all my springs and they are fine.
    Dont know about the drop links they look ok and i did the pull check with no clunks
    what else could it be?
    It almost seems like something at the front is loose and vibrates on rough road.
    And these vibrations can be felt through the steering wheel
    What sort of speeds and conditions?
    If it is only between 60 and 70mph then it is most likely to be the front wheel balancing
    Ask for the fine settings to be used
    If it is whilst accelerating between 30mph and 60mph then it may be the steering arms
    Failed drop links give knocking noises and imprecise steering
    However, on braking they can give horrendous vibration through the steering, especially when braking from 40mph to 20mph
    West Midlands
    I cant really narrow it down to certain conditions.
    It just seems random but more often it happens when the road is a bit rough.
    Thinking about it, it may not even be vibration any more, i think the main issue is that i can feel every part of the road through the wheel. it seems like i can feel every little stone i drive over.
    Could something be worn or loose?
    What can you feel through your steering wheel?
    Quote Originally Posted by Exclusive BV View Post
    Nothing now and back to normal
    When the wheel balancing is out the steering wheel can have a vibration between 50mph and 70mph and in extreme cases can also be seen
    Equally, if swapping the front and rears causes a slight change, then have ALL four rebalanced
    I usually find the older wheels swapped from the rear to front can do this, so it is just the two fronts that need rebalanced (as the rears are new)
    With worn front steering arms the steering wheel can be felt vibrating
    The worn front drop links give the steering wheel such a vibration that it can be seen moving vertically when braking
    West Midlands
    I had all 4 wheels balanced to fine settings last month on a new machine and there was little difference in them.
    mmm, it does seem like its up and down movement rather than side to side. But it's only very slight now, since i did the front to back swap it's improved a hell of a lot.
    So am i right in saying that worn drop links would transmit road vibrations through to the steering wheel or is there something else like bushes that i should be looking at?
    That pretty much confirms it is suspension and not wheels then
    The reason you get vibration on unbalanced wheels is due to one wheel pulling up and down on the suspension as it rotates, more than the other, which then pushes and pulls the steering (the weakest point)
    With correctly balanced wheels the next weakest point will pull up and down on the suspension
    Normally this is the drop link and anti-roll bar member, and typically the lower bush will show signs of play first
    Once this has worn this results in a longitudinal vibration along the steering, hence why it appears to vibrate up and down in front of you
    I would therefore suggest you arrange a full inspection of the front suspension, ask for advisories on any play even if minimal
    That is how mine was found, monitored for three months and then advised the one with play had finally worn, with the other side showing signs of play
    West Midlands
    i'll change the drop links then cheap and easy job, then see if it gets better
    Cheers m8
  1. vibrations
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 17:55
  2. Strange vibrations
    By BigWilko in forum Engine & Drivetrain
    Last Post: 13th March 2012, 20:28
  3. Bad vibrations
    By tony tyre 1 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th November 2011, 07:25
  4. Steering vibrations
    By Wilco in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2008, 09:16
  5. Vibrations!!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2008, 11:39
