Results 1 to 2 of 2
Thread: Gear Knob return spring?
    Mar 2011
    maidstone
    Unhappy Gear Knob return spring?
    Hi Guys iv just bought a Signum 2.2 direct (facelift) and realised after putting it in reverse then into 1st, the gear lever doesnt push itself back down. So you end up putting it back into reverse unless you physically push the lever down!?
    Iv had a look at it but cant figure out how it is meant to work? I took some pictures of it but i dont know how t reduce their size to upload them. Any ideas Guys? thanks
    the spring sits in a recess under the gear knob , you wouldnt be a ble to see it unless you remove the gear knob
    and they tend to break when doing this
    only way to remedy it is to aquire a new gear lever from breakers and change the lot or an aftermarket gear knob and get a new spring
  1. handbrake return spring????
    By TimTay in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2015, 14:09
  2. Handbrake Return Spring.
    By Das in forum Suspension, Wheels & Brakes
    Last Post: 16th August 2011, 17:01
  3. Clutch Return Spring
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 14:47
  4. Fitting a clutch return spring
    By Reading1800 in forum Engine & Drivetrain
    Last Post: 10th June 2010, 18:01
  5. clutch pedal return spring
    By smartymarty1971 in forum Engine & Drivetrain
    Last Post: 11th March 2009, 00:00
vauxhall vectra gear knob spring
vectra gear knob reverse spring gear stick reverse spring vauxhall vectravectra selector springhow to you work the spring on a vectra gear stickvectra gear stick return springvectra c gear stick springvectra gear stick spring picturevectra gear change springvectra 07 gear stick not retuning after reversregear knob springvectra reverse gear spring
