Thread: Saab 150
    Regular Member Mopar Man's Avatar
    herts
    Default Saab 150
    Had a look at a Saab 57 plate 150 today for a friend.
    He said when the EML light comes on he loses power, switch engine off and start its OK.
    So i plugged it in, but only on EOBD as i don't have Saab on my scanner and it came up with air intake leak, witch it hasn't?
    Boost pipes OK, cleaned boost sensor, swirl bar just hanging on
    No hissing from the inter cooler.
    Regular Member Diesel Dude's Avatar
    Norfolk
    My mate had a similar problem on his Astra 150cdti it was the boost solenoid valve blocked, you have the two vacuum pipes on the solenoid then a vent to atmosphere on the back it was the vent that was blocked.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    That code also comes up for dpf blocked too if it has One fitted as that's the code I got but my dpf was blocked up
    South Central England
    9 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    A system leak would be determined by the pressure, flow and temp, so the MAF and MAP/temp sensors could both be culprits.
    Engine : 1.9 CDTi
    Had exactly the same a few weeks ago.
    9 times out of 10 its the egr valve sticking now and again.
  1. Would you still buy a used Saab?
    Last Post: 9th April 2012, 16:16
  2. SAAB 9-3 v VEC-C
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 18:21
  3. Saab 93?
    By dh.dti in forum General Chat
    Last Post: 10th September 2009, 19:52
  4. Saab 9-3 1.9 TID 150
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 03:19
  5. Saab 9-3 150 Tid
    By maxcars1 in forum Diesel Engine related
    Last Post: 30th November 2007, 21:48
