Results 1 to 10 of 16
Thread: HELP!! car wont turn over!!!
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default HELP!! car wont turn over!!!
    Just been thru to my mate's house all was well..........
    Got in my car to come home and nothing, just a click when i turn the key.
    The battery is fine all electrics working, doors, windows Hid's everything. But when i went to start CLICK from what sounds like where the starter motor should be. no engine light or anything, so got my mates to give me a push and she fired up no bother. Got home turned her off, went to start her again and CLICK, is this going to be a starter motor???? Wife is going nuts! as she is ment to be going to the xfactor live tour on sunday and need to get it sorted by then or i will be hung! Please help!
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    try to give it a whack as some one turns it over it might just be stuck
    Oct 2007
    Shropshire
    Are you sure its not the battery? When mine was flat all the windows etc worked fine, just would not start!
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    BumpStart And Find Oot
    Just Read Full Post lol
    Aye Dink It Wiv Hammer Or Trolley Jack Pole Tim...You Think A Bump Woulda Cured It Likes
    Nov 2010
    BRECHIN
    well tried the jumpleads at my mates, and did nout. worked with cars for years def not a flat battery. sounding stupid here but from what i can see the starter is right at the back of the engine by the manifold can barely see it with a torch! also noticed a relay in the fusebox was getting warm. a yellow one. any insight on that?
    Aug 2010
    Luton
    put it in 3rd and rock car forwards and backwards a few times it might free it ( for the life of me I cant remember what the bit is called that spins out to spin the flywheel) but it might just be some dirt
    dont know about relay
    Nov 2010
    BRECHIN
    solanoid?
    Tried rocking it back and forth and still no go. Gonna have a sleep on it and go out first light and get stuck right in. I have to sort it, my life depends on it!
    Aug 2010
    Luton
    pinion i think
    Jan 2010
    glasgow
    drop the starter and fire a set of jump leads on it see if it spins do this from a sep battery if it dont spin see if you can soak the shaft etc in wd40 or penatrating spray oil it may get it going but will only be a short temp fix mate you will ether need to overhall the starter or get a re con 1
    Nov 2010
    BRECHIN
    well will get my neighbour over first thing with jump leads, just incase. if that fails will be on the hunt for a starter asap! anyone know of a good place to get 1 quick? very quick!!
  1. turn the key and nothing!!!!!- Wont start
    By Rupster_69 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2013, 13:13
  2. Vectra wont turn over
    By stevie b in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2012, 20:57
  3. please help vectra 2.2 dti wont turn over
    By deano1 in forum Engine & Drivetrain
    Last Post: 20th May 2011, 21:37
  4. z22se wont turn over HELP
    By mike060280 in forum Engine & Drivetrain
    Last Post: 13th April 2011, 18:33
  5. display wont turn off
    By Sauce in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 19:40
