Thread: Warped my discs
    Regular Member Mopar Man's Avatar
    herts
    Default Warped my discs
    I need to upgrade my front brakes on my 150 Elite.
    Will 302s be good enough with some decent discs, or do i need to go bigger?
    The car is pushing nearly 200Hp and i do heavy braking at high speed.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    302mm will make a difference for you.. a nice set ot mtec grooved/drilled disks make a nice set... 314mm do make even more of a difference and the disks and pads are still in the same price range as the 302. If you go to the 345mm hirsch/vxr brakes then the price goes up significantly as do the disks and pads...
    herts
    Only reason I'm asking about the 302s is because there are some for sale.
    Jun 2009
    South Coast
    go for it.. take the opportunity to upgrade your brake hoses while you are at it to a set of braided Goodridge..
    Woodbridge
    How much extra are the caliipers?
    herts
    Found out the 302s use the same pad and calipers as the standard, so 314s are the way forward.
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    so can i put 302 on my elite with standard calipers
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    No same caliper but carriers are different like 314 use same caliper as 345 but carriers are bigger !
    herts
    Picked up some front VXR Discs and calipers today, from Metro car breakers. £110 the lot, well chuffed
    just had to adjust my backing plates a bit.
    Regular Member david.aka.judas's Avatar
    Suffolk
    Quote Originally Posted by Caveman_nige View Post
    get Hel lines instead - cheaper and just as good.
  1. help my new xp splitters warped!
    By Даниил in forum Styling
    Last Post: 8th August 2011, 09:51
  2. Warped brake disks, myth?
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2010, 17:53
  3. warped exhaust manifold
    By Paul_O in forum Engine & Drivetrain
    Last Post: 4th August 2010, 09:47
  4. Brake problems, Bleeding, Warped Disc?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 24th December 2009, 13:56
  5. Warped........but funny!!!!!
    By Mrs D in forum Comedy & Humour
    Last Post: 13th August 2005, 01:20
